    Weatherunderground - currently - hourly - daily - configurable
    126 Posts 26 Posters 249.5k Views 13 Watching
      RedNax Module Developer @djsunrise19
      @djsunrise19 Thanks for spotting my mistake :D I’ve modified the readme accordingly. Enjoy!
        MagicCrumps1
        it’s taking me forever but How do i change pws: ‘locid:’ for san francisco? I cant find the location ID for my city using google
        • strawberry 3.141S
          Can be any WU api location info.
          US Example: NY/New_York
          Example: locid:NLXX8014;loctype:1
          so just change it to CA/San_Francisco
            MagicCrumps1
            I’m getting a blank screen. Any idea why?
            		module: 'MMM-WunderGround',
            		position: 'top_right',
            		header: 'Weather Forecast',
            		    apikey: 'a1fa37eaff91b5450c',
            		    pws: 'CA/San_Francisco',
            		    fctext: '1',
            			  fcdaycount: '5',
            			  fcdaystart: '0',
            			  hourly: '1',
            			  hourlyinterval: '3',
            				hourlycount: '2',
            				alerttime: 1000,
            				alerttruncatestring: 'english:'
            R 1 Reply Last reply
              Config looks good, could you have a look at your logs?
              See here for some troubleshootign info: https://forum.magicmirror.builders/topic/86/how-to-troubleshoot
                RedNax Module Developer @MagicCrumps1
                @MagicCrumps1 On the other hand, you api key seems to be invalid. (if the key in your post is indeed your key):
                  "response": {
                  "version":"0.1",
                  "termsofService":"http://www.wunderground.com/weather/api/d/terms.html",
                  "features": {
                	"error": {
                		"type": "keynotfound"
                		,"description": "this key does not exist"
                M 2 Replies Last reply
                  MagicCrumps1 @RedNax
                    @RedNax Still not working. Sorry, I should have included that I added a few extra keys to my personal api key thus making them invalid.
                    Loading config …
                    Loading module helpers …
                    No helper found for module: MMM-WunderGround.
                    All module helpers loaded.
                    Starting server op port 8080 …
                    Server started …
                    Starting module: newsfeed
                    Sockets connected & modules started …
                    Launching application.
                    • K
                      KirAsh4 Moderator
                      That looks like everything did load up properly there. There’s a way to look at electron’s console logs but I don’t know what the keystroke is (maybe CTRL-W?). But, at times like this, I find it’s easier/faster for me to debug by using a different machine with Chrome/Firefox and load up the mirror that way by going to the rpi’s IP and port: http://10.0.0.1:8080 (assuming your rpi’s IP is 10.0.0.1, change it to match yours.) Black screen or not, you can always hit F12 on a windows browser and pull up the console log. Look for Javascript errors.
                        MagicCrumps1
                        Thanks KirAsh4 and RedNax! I resolved it. What happened was that I entered
                        locationid: ‘5391959’
                        on the currentweather module.
                        I decided to delete the locationid key and left it blank and voila! It works now! You guys rock!
                          MagicCrumps1
                          @RedNax do you happen to know why my MMM-WunderGround module is not showing the forecast?
                          0_1465449394807_upload-42252077-f895-4414-a919-4178207675af
                            Any errors in the console or the web inspector?
                              Shockwave
                              This module is fantastic, thank you. I was wondering about getting weather for multiple areas. Is there a way to do that within the program or would I need to copy the directory to say, MMM-WunderGround2?
                                RedNax Module Developer @Shockwave
                                @Shockwave Thanks :) To use the module twice you can just enter multiple wunderground config sections in your config.js. It will then display both. There is no need to install the actual module twice.
                                  Shockwave @RedNax
                                  @RedNax Hey thanks for the quick response! I have 2 locations up and running and great. Unfortunately I now have another question. :smile: There is a special weather statement for one of my 2 locations, and it popped up an alert which is really cool. However, the popup alert just said, Special Statement, which is just the subject text, for lack of a better description. Is that the expected behavior?
                                  Special Statement
                                  Issued: 1:49 PM EDT Jun. 27, 2016 – National Weather Service
                                  … A strong thunderstorm with intense lightning will impact central
                                  Oconee County until 230 PM EDT…
                                  At 148 PM EDT… Doppler radar was tracking a strong thunderstorm
                                  with intense lightning 5 miles northwest of Walhalla… or near
                                  Oconee State Park… moving southeast at 25 mph.
                                  Locations to be impacted include…
                                  Walhalla… Westminster… Oconee State Park… Lake Keowee and Mountain
                                  Rest.
                                  In addition to intense lightning… pea size hail and wind gusts up to
                                  40 mph will be possible in these areas.
                                    pugsly
                                    Quick question about this module and some of the icon classes. I found which ones I need to change for the high and low temperature in the custom.css file, which works great. What I can’t figure out is how come I can’t get sunset to change to orange, and sunrise to yellow. I am pretty sure its the right icon.
                                    .wi.wi-thermometer {
                                      color: #ff0000; /* Red */
                                    .wi.wi-thermometer-exterior {
                                      color: #0000ff; /* Blue */
                                    .wi.wi-umbrella {
                                      color: white;
                                    wi.wi.sunset {
                                      color: orange;
                                    wi.wi.sunrise {
                                      color: yellow;
                                      pugsly
                                      Nevermind, I found it.
                                      .wi.dimmed.wi-sunset
                                      and
                                      .wi.dimmed.wi-sunrise
                                        @Shockwave Sorry for the late reply… missed your post here…
                                        It’s not expected behaviour. The entire message should be displayed in the popup. It may have something to do with the
                                        				alerttruncatestring : "english:"
                                        property…
                                        Try changing t to an empty string.
                                        Also, could you post the entire result of your api call?
                                        http://api.wunderground.com/api/<apikey>/conditions/forecast10day/astronomy/alerts/lang:EN/q/<value of your pws property>.json
                                          Snoevit
                                          Couple of things…
                                          Wind icons.
                                          Ive tried copy weather-icons-wind.css to the vendor folder and change vendor.js with no luck.
                                          I also tried to change getStyles: in the MMM-WunderGround.js file to use the ...-wind.cssfile located in the module folder.
                                          Since its just the wind icons do i need to do anything special to use them?
                                          How can i remove Sunrise/Sunset and mm (rain amount)
                                          Im also wondering how to change the unit km/tim (km/h Swedish translate) to m/s?
                                          As soon as i try to change anything to remove anything involved “Sunset” or “mm” everything breaks. I cant even remove /astronomy from getParams:. (Wich i believe is the wrong way to do it, But its better to try your way ahead then to hide in the corner.)
                                          I want it to look more like this ->
                                          I had no problems changing the default weather modules this way, but since im a newbie i cant figure this one out. :P
                                            Pauliolio
                                            Hi @RedNax
                                            Could you explain the ‘pws’ attribute a little please?
                                            What’s ‘loctype’? Are there any other valid values?
                                            ‘locid’ is giving a little trouble. I can’t find anything on Wunderground about it, but if I use the ‘Search Locations’ tool, and when my area comes up, pick a different station (one closer to where I am), the url changes to this:
                                            https://www.wunderground.com/cgi-bin/findweather/getForecast?query=pws:IBATTLE3&MR=1
                                            So I’ve put your example config into config.js, set my apikey, and changed the locid to IBATTLE3.
                                            I left the default weather module in the config file while I was getting your one set up, and when they were both on screen they seemed to be giving weather for two different places as the sunrise times were different by about an hour so I’m really not confidant that I’ve got the correct locid here…
                                            Many thanks.
                                            • 3 / 7
