    Changing Module Display Width
    24 Posts 6 Posters 23.2k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy @cowboysdude
      @cowboysdude
      Perfect thanks
      • cowboysdudeC Offline
        cowboysdude Module Developer @johnnyboy
        @johnnyboy said in Changing Module Display Width:
        @cowboysdude
        Perfect thanks
        You’re welcome!
        You can also do this:
            module: 'MMM-History',
            position: 'top_right',
        	 maxWidth: "33%"
        johnnyboyJ 1 Reply Last reply Reply Quote 1
        • brobergB Offline
          broberg Project Sponsor @johnnyboy
          @johnnyboy It will change the height/width of the module “container”, it will not affect the size of objects, images or fonts. Normally the module “container” will adapt to the size of it’s content. but with the width/height specified you force it to be a set width/height.
          johnnyboyJ 1 Reply Last reply Reply Quote 2
            johnnyboy @broberg
            @broberg
            Ahhhhhhhhh… Gotcha ;-)… reduce the % of the container also reduces it’s contents in relation. Thanks.
            brobergB 1 Reply Last reply Reply Quote 1
            • brobergB Offline
              @johnnyboy well, not entirely, the content (text etc.) don’t change in size, all you do is changing the surface that the content can take up.
              like moving from a big garage to a small, you still have the same amount of stuff but less area to put it in, so the stuff that doesn’t fit spills over and out on to the yard.
                johnnyboy @broberg
                @broberg
                Oh, ok… Well I will play about with it anyway just to see what that does to it… just so I will know for experience as its another learning curve i’ve learned
                • brobergB Offline
                  @johnnyboy You can do a lot to the Magicmirror and it’s module just by editing the css,
                  Here is a good reference for CSS : https://www.w3schools.com/css/
                  And css for beginners : http://www.htmldog.com/guides/css/beginner/
                    @cowboysdude said in Changing Module Display Width:
                    	 maxWidth: "33%"
                    Oooooo MM didn’t like that :-) So I musta entered something wrong or didn’t enter something I should have? Can you please guide me to what part I did wrong here?
                        module: 'MMM-WunderGround',
                        position: 'top_left',
                    	 maxWidth: "33%"
                    apikey: 'pws: mydetailshere',
                    hourly: '1',
                    fctext: '1'
                    • brobergB Offline
                      @johnnyboy maxWidth isn’t specified for the WunderGround module. So you can’t use the same config option there as you could with MMM-History.
                      Confusing I know, but most modules don’t use size settings in the config since it’s better to set that with css code.
                      Custom css-code is put in the file custom.css that can be found in the css folder.
                        johnnyboy @broberg
                        @broberg
                        Ah, ok… I was jumping ahead of myself there… so I will try
                        .MMM-WunderGround {
                            width : 200px;
                        200px; or whatever looks good.
                        Thanks again.
