    Changing Module Display Width
    24 Posts 6 Posters 26.1k Views 6 Watching
    • johnnyboyJ Offline
      johnnyboy @broberg
      @broberg
      Ahhhhhhhhh… Gotcha ;-)… reduce the % of the container also reduces it’s contents in relation. Thanks.
        broberg Project Sponsor @johnnyboy
        @johnnyboy well, not entirely, the content (text etc.) don’t change in size, all you do is changing the surface that the content can take up.
        like moving from a big garage to a small, you still have the same amount of stuff but less area to put it in, so the stuff that doesn’t fit spills over and out on to the yard.
        johnnyboyJ 1 Reply Last reply Reply Quote 1
          johnnyboy @broberg
          @broberg
          Oh, ok… Well I will play about with it anyway just to see what that does to it… just so I will know for experience as its another learning curve i’ve learned
            @johnnyboy You can do a lot to the Magicmirror and it’s module just by editing the css,
            Here is a good reference for CSS : https://www.w3schools.com/css/
            And css for beginners : http://www.htmldog.com/guides/css/beginner/
              johnnyboy @cowboysdude
              @cowboysdude said in Changing Module Display Width:
                  module: 'MMM-History',
                  position: 'top_right',
              	 maxWidth: "33%"
              Oooooo MM didn’t like that :-) So I musta entered something wrong or didn’t enter something I should have? Can you please guide me to what part I did wrong here?
                  module: 'MMM-WunderGround',
                  position: 'top_left',
              	 maxWidth: "33%"
              apikey: 'pws: mydetailshere',
              hourly: '1',
              fctext: '1'
                @johnnyboy maxWidth isn’t specified for the WunderGround module. So you can’t use the same config option there as you could with MMM-History.
                Confusing I know, but most modules don’t use size settings in the config since it’s better to set that with css code.
                Custom css-code is put in the file custom.css that can be found in the css folder.
                  johnnyboy @broberg
                  @broberg
                  Ah, ok… I was jumping ahead of myself there… so I will try
                  .MMM-WunderGround {
                      width : 200px;
                  200px; or whatever looks good.
                  Thanks again.
                    johnnyboy @johnnyboy
                    I changed mines to 250px as that was about maxed out or else it would move the large Moon icon onto top bar and would become 1/3 of its original size and not look right, or look good… so I’m pretty happy at that.
                    However, I thought to do the same thing to the calendar that’s directly opposite, on the top right…to keep the aspect look… Nope! It wont budge for some reason?
                    Side effect now is a slight 5 - 7 second load time to WunderGround, Calendar, and News feed on bottom bar… No idea if this is linked or no?No effect at all on Compliments or SimpleLogo.
                    .Module_calendar {
                    width : 250px;
                    No idea if this is relevant, but should I have included the calendar header Uk Holidays? My calendar is also linked to Google Calendar so no idea if that could be a reason either why it wont allow width to be adjusted, but thought to mention
                      @johnnyboy I think it should be just .calendar not .Module_calendar
                        johnnyboy @broberg
                        @broberg
                        ok will try that now… Yes that did it… I didn’t know not to include .Module there… Thought they all had the same command, apart from MMM
                          deadherring
                          I have my MM configured vertically and a lot of the calendar entries get cut off. I’m trying to widen the calendar.
                          This is what I’ve added to custom.css but I’m not seeing any change. (sorry, I’m not sure how to make the code show up in a special way the way others do)
                          body {
                          .MMM-calendar {
                          width : 350px;
                          Can someone point me in the right direction in terms of what I’m doing wrong?
                          Thanks,
                          Nathan
                            broberg Project Sponsor @deadherring
                            @deadherring
                            .calendar {
                            width : 350px;
                            It’s not supposed to be inside the body{} and since it is a default/stock module it doesn’t use the MMM prefix like other modules does so the class name of the module is just .calendar
                              deadherring
                              Thanks @broberg, that worked, I can see that changes I make are taking effect now.
                              I set the calendar to 450px. However, as you can see from this
                              picture, the date text just shifted over to the right and is now covering the weather forecast, rather than the text from the calendar entry expanding. What I’m trying to accomplish is to get the full calendar item text to show. Is there a way to do that?
                              Thanks,
                              Nathan
                              • cowboysdudeC Offline
                                @deadherring said in Changing Module Display Width:
                                Thanks,
                                Nathan
                                Readjust it to a number that works to get it away from the weather… you have it at 450, try 400.
                                  @deadherring add maxTitleLength : 50, in the calendar config, default is set to 25
                                    deadherring
                                    Thanks, that worked!
                                    One thing I’m seeing is that my work calendar (Exchange) is not showing. I have A Google calendar that is updating but the Exchange is not. I can configure with a .ics file and .html and neither seems to work. If I copy and paste the Exchange url from config.js to a web browser it works fine, but it is not updating on the MagicMirror. I tried restarting the Pi but no go.
                                    Any ideas on how I can troubleshoot? I haven’t updated the MM software in a few months, so I doubt I’m on the latest version.
                                    Thanks,
                                    Nathan
                                      Srikanth 666 @cowboysdude
                                      @cowboysdude
                                      It’s not working, it’s showing error
                                      what can I do
