    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 427.7k Views 51 Watching
      bminer1 @Mykle1
      @Mykle1 Can you share how you did this?
      strawberry 3.141S Mykle1M 2 Replies Last reply
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @bminer1
        @bminer1
        @strawberry-3.141 said in Throwing down the gauntlet:
        if someone wants to achieve the same, actually there is the module wunderground twice (center and right), but once the forecast and the other time the current weather is hidden
        .region.top.center .MMM-WunderGround table.small, //selector for forecast
        .region.top.right .MMM-WunderGround table:not(.small), //selector for current weather
        .region.top.right .MMM-WunderGround table.small td:nth-child(6) { //selector for rain amount
          display:none;
        B 1 Reply Last reply
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @bminer1
          @bminer1 said in Weatherunderground - currently - hourly - daily - configurable:
          There you go. You got it from the source. (I was sleeping) Virtually every entry in my custom.css file is commented with
          /* Thanks to Strawberry 3.141 */
            bminer1 @strawberry 3.141
            @strawberry-3.141 I tried this. No luck. The full data is in both top center and top left (i have mine on the other side and replaced “right” with “left”). I put the code in both the custom.css and the wunderground.css file. I think i am missing something.
            • strawberry 3.141S
              @bminer1 can you share your wunderground config
                @strawberry-3.141
                Here is the Config:
                		    module: 'MMM-WunderGround',
                		    position: 'top_left',
                		        apikey: '', // private; don't share!
                		        pws: 'pws:KNJMOORE3', //Chester Ave
                			hourly: '1',
                		        fctext: '1',
                		        fcdaycount: "9",
                		        fcdaystart: "1",
                		        hourlyinterval: "3",
                		        hourlycount: "3",
                		        alerttime: 30000,
                		        alerttruncatestring: "english:",
                			roundTmpDecs: '1',
                		    	layout: "vertical",
                			windunits: "mph",
                			coloricon: true,
                		    	sysstat: 0
                • strawberry 3.141S
                  @bminer1 your config leads to a different layout
                  .region.top.left .MMM-WunderGround div.module-content > div > :not(table),
                  .region.top.center .MMM-WunderGround div.module-content > div > table {
                  	display: none;
                    @strawberry-3.141 And that worked! I swear, i have no clue what we noobs would do without you.
                    Mykle1M 1 Reply Last reply
                    • Mykle1M
                      Yeah, he is the bomb!
                        c502
                        Absolutely the best weather module out there. Hands down.
                        As someone who went to school for meteorology, weather runs deep in my veins. I know that we are already able to grab alerts from Wundergound, but is there a way to take those alerts further? I’m not sure if this would be an entirely new module, or just an additional feature.
                        The National Weather Service already sends out XML/RSS feeds all the way down to the county level. If there was a way to “watch” that feed and check for specific alerts, then make that show up on the mirror in red lettering (or something eye-catching) with an icon to go with it (thunderstorm, tornado, etc). Perhaps even scroll in a crawl like on TV news stations. Those XML files also contains specific parts. Title (Tornado Warning), description (Tornado Warning for Jefferson County until 9:45pm), and also narrative and preparedness statement. Finally, each XML file includes an expiration time.
                        I know that would take a lot of work, but it’s just something cool that could lead to more and more implementation over the long run. National Weather Service XML - Jefferson Co., KY
                        RedNaxR 1 Reply Last reply
                        • RedNaxR
                          RedNax Module Developer @c502
                          @c502 Thanks!
                          The initial xml doesn’t hold all the info:
                          This atom/xml feed is an index to active advisories, watches and warnings
                          issued by the National Weather Service.  This index file is not the complete
                          Common Alerting Protocol (CAP) alert message.  To obtain the complete CAP
                          alert, please follow the links for each entry in this index.  Also note the
                          CAP message uses a style sheet to convey the information in a human readable
                          format.  Please view the source of the CAP message to see the complete data
                          set.  Not all information in the CAP message is contained in this index of
                          active alerts.
                          You’ll have to follow the links in the initial xml message to get the full info. You could probably use the newsfeed module as an initial startingpoint…
                          O 1 Reply Last reply
                          • A
                            anatius
                            Hi RedNax,
                            Love your module and am using it ever since I have my mirror. One small thing though: WUnderground currently has two identical alerts (both “type”: “WIN”) for my PWS. This leads to the identical text being shown on the module. It would be great if the module checked whether an alert with the respective type already exists and only displays the warning once… The relevant extract from WUnderground json is as follows:
                            //	"alerts": [
                            		"type": "WND",
                            		"wtype_meteoalarm": "1",
                            		"wtype_meteoalarm_name": "Wind",
                            		"level_meteoalarm": "2",
                            		"level_meteoalarm_name": "Yellow",
                            		"level_meteoalarm_description": "The weather is potentially dangerous. The weather phenomena that have been forecast are not unusual, but be attentive if you intend to practice activities exposed to meteorological risks. Keep informed about the expected meteorological conditions and do not take any avoidable risk.",
                            		"description": "Potential disruption due to wind from 5:22PM CET SAT until 11:59PM CET SAT",
                            		"date": "2017-02-25 17:24:18 GMT",
                            		"date_epoch": "NA",
                            		"expires": "2017-02-25 22:59:00 GMT",
                            		"expires_epoch": "NA",
                            		"message": "Potential disruption due to wind from 5:22PM CET SAT until 11:59PM CET SAT)",
                            		"phenomena": "NA",
                            		"significance": "NA",
                            		"attribution": "Information provided by , <a href="http://meteoalarm.eu/">EUMETNET - MeteoAlarm</a> Note: Time delays between this website and <a href="http://meteoalarm.eu/">Meteoalarm.eu</a> are possible. For the most up-to-date information about alert levels as published by the participating National Meteorological Services, please visit <a href="http://meteoalarm.eu/">Meteoalarm</a>. For terms of use of this information, and copyright information, see <a href="http://meteoalarm.eu/">Meteoalarm</a> Terms of Use."
                            		"type": "WIN",
                            		"wtype_meteoalarm": "2",
                            		"wtype_meteoalarm_name": "Snow/Ice",
                            		"description": "Potential disruption due to snow and ice from 8PM CET FRI until 9AM CET SAT",
                            		"date": "2017-02-25 01:00:00 GMT",
                            		"date_epoch": "NA",
                            		"expires": "2017-02-25 08:00:00 GMT",
                            		"message": "Potential disruption due to snow and ice from 8PM CET FRI until 9AM CET SAT)",
                            		"phenomena": "NA",
                            		"type": "WIN",
                            		"wtype_meteoalarm": "6",
                            		"wtype_meteoalarm_name": "Extreme low temperature",
                            		"description": "Potential disruption due to extreme low temperatures from 8PM CET FRI until 9AM CET SAT",
                            		"date_epoch": "NA",
                            		"message": "Potential disruption due to extreme low temperatures from 8PM CET FRI until 9AM CET SAT)",
                            		"phenomena": "NA",
                            • O
                              ostfilinchen @RedNax
                              @RedNax is it possible to disable these weatherwarnings?
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @ostfilinchen
                                @ostfilinchen try config option show_popup: false
                                • O
                                  ostfilinchen @strawberry 3.141
                                  @strawberry-3.141 i don’t mean an popup. I mean the weatherwarnings in the module
                                  • strawberry 3.141S
                                    @ostfilinchen the alerttext gets prepended to the forecasttext in this if statement https://github.com/RedNax67/MMM-WunderGround/blob/master/MMM-WunderGround.js#L912 you can only disable the forecasttext in complete but not the alert only. For this you have to try to get a working css selector and apply the rule display:none;
                                    • T
                                      trividar
                                      The yellow warning “strong wind” shows the whole time. How can i disable this warning?
                                      • O
                                        ostfilinchen @trividar
                                        @trividar Same thing Here but with 3 Warnings
                                        • RedNaxR
                                          RedNax Module Developer @ostfilinchen
                                          @ostfilinchen And you’re certain the warning isn’t present in the wunderground payload?
                                          Mine shows three because the payload has three warnings:
                                          0_1488202611473_upload-a8dda26e-b296-4900-91c7-6ae6fa233148
                                          	"alerts": [
                                          		"type": "WND",
                                          		"description": "Severe gusts of 80-90 km/h.BE AWARE of debris being blown around. Localised outdoor activity disruption is possible due to debris.>",
                                          		"date": "1970-01-01 00:00:00 GMT",
                                          		"date_epoch": "NA",
                                          		"expires": "2017-02-23 23:59:00 GMT",
                                          		"message": "Severe gusts of 80-90 km/h.BE AWARE of debris being blown around. Localised outdoor activity disruption is possible due to debris.>)",
                                          		"phenomena": "NA",
                                          		"attribution": "Information provided by , <a href='http://meteoalarm.eu/'>EUMETNET - MeteoAlarm</a> Note: Time delays between this website and <a href='http://meteoalarm.eu/'>Meteoalarm.eu</a> are possible. For the most up-to-date information about alert levels as published by the participating National Meteorological Services, please visit <a href='http://meteoalarm.eu/'>Meteoalarm</a>. For terms of use of this information, and copyright information, see <a href='http://meteoalarm.eu/'>Meteoalarm</a> Terms of Use."
                                          		"type": "WIN",
                                          		"description": "Potential disruption due to snow and ice from 6AM CET SAT until 8:59AM CET SAT",
                                          		"date": "2017-02-25 06:28:03 GMT",
                                          		"date_epoch": "NA",
                                          		"expires": "2017-02-25 07:59:00 GMT",
                                          		"message": "Potential disruption due to snow and ice from 6AM CET SAT until 8:59AM CET SAT)",
                                          		"phenomena": "NA",
                                          		"type": "WRN",
                                          		"wtype_meteoalarm": "3",
                                          		"wtype_meteoalarm_name": "Thunderstorms",
                                          		"description": "Potential disruption due to thunderstorms from 4PM CET MON until 9:59PM CET MON",
                                          		"date": "2017-02-27 11:46:02 GMT",
                                          		"date_epoch": "NA",
                                          		"expires": "2017-02-27 20:59:00 GMT",
                                          		"message": "Potential disruption due to thunderstorms from 4PM CET MON until 9:59PM CET MON)",
                                          		"phenomena": "NA",
                                          • O
                                            @RedNax I don’t know, But the dwd warningmodule doesn’t Show any warnings. And btw the warnings are since friday there
                                            • 10
                                            • 7 / 10
