    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 427.7k Views 51 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @bminer1
      @bminer1 i think you have another issue, because the text wi-from-sw should actually be an icon
      • RedNaxR
        RedNax Module Developer @bminer1
        @bminer1 Pull the new version ;)
        B 1 Reply Last reply
        Reply Quote 3
          bminer1 @RedNax
          @RedNax much better! Thank you!
          Just one thing, aesthetically, the little wind icons arent all uniform.0_1487352669390_Screen Shot 2017-02-17 at 12.29.56 PM.png
          RedNaxR 1 Reply Last reply
          • RedNaxR
            @bminer1 Made the fontsize smaller in css.Please try it.
            You can try to tweak this is it still behaves oddly.
            .MMM-WunderGround .smaller {
                font-size: 60%;
            O K 2 Replies Last reply
            • O
              ostfilinchen @RedNax
              @RedNax After the latest update, the Module wouldn’t start :-(
              • RedNaxR
                RedNax Module Developer @ostfilinchen
                @ostfilinchen Anything in the logs? Works fine here…
                IT could be your chosen weatherstation is feeding ‘estimated’ forecasts. The module skips those as they vary wildly (0 to 15 degrees C)… Should clear up on it’s own in that case.
                Update: There was no logging on skipping estimated forecasts. Added it just now.
                O 1 Reply Last reply
                • O
                  @RedNax in dev Mode it says: uncaught TypeError: cannot read property ‘cloudy’ of undefined. MMM-WunderGround.js Line 877
                  • RedNaxR
                    @ostfilinchen Some obsolete coloricon code got in the way it seems. Are you not using the coloricons?
                    O 2 Replies Last reply
                    • cowboysdudeC
                      Thanks @RedNax I still remember the day I was trying to get this module to work [NOOOOOB LOL] and you helped me I appreciated that! Now the colors are just awesome!!!
                      I’m finding that myself personally colors are making my mirror stand out and I like it… I’m sure many other users do as well!
                      Thanks!
                      • O
                        @RedNax I Use the colored Icons. After the last update it works. But i’m Not sure if it goes wrong with an other weather like cloudy…
                        • O
                          @RedNax still the Same error. If the weather is cloudy on daytime, the Module don’t starts or hangs up. Can u please check this?
                          • RedNaxR
                            @ostfilinchen Cannot reproduce your error. We have cloudy conditions here now and everything works fine.
                            One thing i did notice when using the remote control module is that it places the icon tables in the config.js for some reason. Could you check your config? Maybe you can pm me your config section.maybe it’s some combination of settings…
                            • O
                              @RedNax I Start my mirror this afternoon in dev-mode. I will Check if I get an error. Also today i will send you my config. And yes. I Use the Remote control.
                              I also have Noticed that the Module scheduler not work. But there i have to Check the dev-mode.
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @Mykle1
                                @RedNax said in Weatherunderground - currently - hourly - daily - configurable:
                                Mykle1: I have to run off to work right now but I will “give it a go” as soon as I get home. I’ll let you know. Thanks for this.
                                I meant to get back to you, RedNax. It’s working nicely for me, and with the help of Strawberry, I’m running it twice. Once for just the current weather, under the clock, top center, and once for just the forecast, top right. Exactly the way I wanted it.
                                  bminer1 @Mykle1
                                  @Mykle1 Can you share how you did this?
                                  strawberry 3.141S Mykle1M 2 Replies Last reply
                                  • strawberry 3.141S
                                    @bminer1
                                    @strawberry-3.141 said in Throwing down the gauntlet:
                                    if someone wants to achieve the same, actually there is the module wunderground twice (center and right), but once the forecast and the other time the current weather is hidden
                                    .region.top.center .MMM-WunderGround table.small, //selector for forecast
                                    .region.top.right .MMM-WunderGround table:not(.small), //selector for current weather
                                    .region.top.right .MMM-WunderGround table.small td:nth-child(6) { //selector for rain amount
                                      display:none;
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @bminer1
                                      @bminer1 said in Weatherunderground - currently - hourly - daily - configurable:
                                      There you go. You got it from the source. (I was sleeping) Virtually every entry in my custom.css file is commented with
                                      /* Thanks to Strawberry 3.141 */
                                        bminer1 @strawberry 3.141
                                        @strawberry-3.141 I tried this. No luck. The full data is in both top center and top left (i have mine on the other side and replaced “right” with “left”). I put the code in both the custom.css and the wunderground.css file. I think i am missing something.
                                        • strawberry 3.141S
                                          @bminer1 can you share your wunderground config
                                            @strawberry-3.141
                                            Here is the Config:
                                            		    module: 'MMM-WunderGround',
                                            		    position: 'top_left',
                                            		        apikey: '', // private; don't share!
                                            		        pws: 'pws:KNJMOORE3', //Chester Ave
                                            			hourly: '1',
                                            		        fctext: '1',
                                            		        fcdaycount: "9",
                                            		        fcdaystart: "1",
                                            		        hourlyinterval: "3",
                                            		        hourlycount: "3",
                                            		        alerttime: 30000,
                                            		        alerttruncatestring: "english:",
                                            			roundTmpDecs: '1',
                                            		    	layout: "vertical",
                                            			windunits: "mph",
                                            			coloricon: true,
                                            		    	sysstat: 0
                                            • 10
                                            • 6 / 10
