    Weatherunderground - currently - hourly - daily - configurable
    182 Posts 47 Posters 427.7k Views 51 Watching
    • O
      ostfilinchen @RedNax
      @RedNax i can’t say why but now after a while, it looks correct.
      RedNaxR 1 Reply Last reply
      • RedNaxR
        RedNax Module Developer @ostfilinchen
        @ostfilinchen There’s a new version. I left my test in which just used metric. Imperial users wouldn’t be happy. I’ve also added trim to the wordwrap function so here aren’t any trailing spaces
          bminer1
          Im still only getting the Icons. How do i get those nicer pictures?
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @bminer1
            @bminer1 Did you try coloricon: true?
            B 2 Replies Last reply
              bminer1 @strawberry 3.141
              @strawberry-3.141
              I swear you guys are way too talented! Fixed.
                @strawberry-3.141 Im sure you can help me out with something else. The wind direction in the forecast is pushing the module really far into the center of the screen. Is there a way i can change the forecast wind direction to shrink it up a bit? Everything at the top seems to be really far in space. I know i could always go back to the vertical but i like the horizontal too.
                strawberry 3.141S RedNaxR 2 Replies Last reply
                • strawberry 3.141S
                  @bminer1 i think you have another issue, because the text wi-from-sw should actually be an icon
                  • RedNaxR
                    RedNax Module Developer @bminer1
                    @bminer1 Pull the new version ;)
                    B 1 Reply Last reply
                    Reply Quote 3
                      bminer1 @RedNax
                      @RedNax much better! Thank you!
                      Just one thing, aesthetically, the little wind icons arent all uniform.0_1487352669390_Screen Shot 2017-02-17 at 12.29.56 PM.png
                      • RedNaxR
                        @bminer1 Made the fontsize smaller in css.Please try it.
                        You can try to tweak this is it still behaves oddly.
                        .MMM-WunderGround .smaller {
                            font-size: 60%;
                        O K 2 Replies Last reply
                        • O
                          @RedNax After the latest update, the Module wouldn’t start :-(
                          • RedNaxR
                            @ostfilinchen Anything in the logs? Works fine here…
                            IT could be your chosen weatherstation is feeding ‘estimated’ forecasts. The module skips those as they vary wildly (0 to 15 degrees C)… Should clear up on it’s own in that case.
                            Update: There was no logging on skipping estimated forecasts. Added it just now.
                            O 1 Reply Last reply
                            • O
                              @RedNax in dev Mode it says: uncaught TypeError: cannot read property ‘cloudy’ of undefined. MMM-WunderGround.js Line 877
                              • RedNaxR
                                @ostfilinchen Some obsolete coloricon code got in the way it seems. Are you not using the coloricons?
                                O 2 Replies Last reply
                                • cowboysdudeC
                                  Thanks @RedNax I still remember the day I was trying to get this module to work [NOOOOOB LOL] and you helped me I appreciated that! Now the colors are just awesome!!!
                                  I’m finding that myself personally colors are making my mirror stand out and I like it… I’m sure many other users do as well!
                                  Thanks!
                                  • O
                                    @RedNax I Use the colored Icons. After the last update it works. But i’m Not sure if it goes wrong with an other weather like cloudy…
                                    • O
                                      @RedNax still the Same error. If the weather is cloudy on daytime, the Module don’t starts or hangs up. Can u please check this?
                                      • RedNaxR
                                        @ostfilinchen Cannot reproduce your error. We have cloudy conditions here now and everything works fine.
                                        One thing i did notice when using the remote control module is that it places the icon tables in the config.js for some reason. Could you check your config? Maybe you can pm me your config section.maybe it’s some combination of settings…
                                        • O
                                          @RedNax I Start my mirror this afternoon in dev-mode. I will Check if I get an error. Also today i will send you my config. And yes. I Use the Remote control.
                                          I also have Noticed that the Module scheduler not work. But there i have to Check the dev-mode.
                                          • Mykle1M
                                            Mykle1 Project Sponsor Module Developer @Mykle1
                                            @RedNax said in Weatherunderground - currently - hourly - daily - configurable:
                                            Mykle1: I have to run off to work right now but I will “give it a go” as soon as I get home. I’ll let you know. Thanks for this.
                                            I meant to get back to you, RedNax. It’s working nicely for me, and with the help of Strawberry, I’m running it twice. Once for just the current weather, under the clock, top center, and once for just the forecast, top right. Exactly the way I wanted it.
                                            • 10
                                            • 6 / 10
