    Update WunderGround
    18 Posts 5 Posters 9.3k Views 4 Watching
    • johnnyboyJ Offline
      johnnyboy
        broberg Project Sponsor @johnnyboy
        @johnnyboy when you are in the Wunderground folder just type git pull and it will download the latest version
        johnnyboyJ 1 Reply Last reply Reply Quote 0
          johnnyboy @broberg
            @johnnyboy no, you have to navigate to the folder in the terminal
            so
            cd MagicMirror
            cd modules
            cd MMM-WunderGround
            then you type in
            git pull
            johnnyboyJ 1 Reply Last reply Reply Quote 1
              johnnyboy @broberg
                johnnyboy @johnnyboy
                  Steff
                  @johnnyboy Potentially you changed something in MMM-WunderGround.jsand you have forgotten about. I am writing potentially because I had a similar situation some month ago with compliments.js- I thought that I definitely have not changed anything, but I had done it and forgotten about it. An extremely simple way to come around this problem:
                  pi@papaspi:~/MagicMirror/modules/MMM-WunderGround $mv MMM-WunderGround.js MMM-WunderGround_mychangedfile.js
                  pi@papaspi:~/MagicMirror/modules/MMM-WunderGround $git pull
                  Now the update should work and if find some changes you still need from your file you can easily extract them from your backup copy MMM-WunderGround_mychangedfile.js.
                    johnnyboy @Steff
                    johnnyboyJ Mykle1M 2 Replies Last reply Reply Quote 0
                          Mykle1 Project Sponsor Module Developer @johnnyboy
                          @johnnyboy said in Update WunderGround:
                          I was instructed to change one item when I first installed it… coloricon: true, … so it shows color.
                          coloricon: true should have been done in your config…js file, along with the other config options for WunderGround. I’m pretty sure I was the one to help you with that, initially. :thumbsup_tone1:
                          Anywho . . . IKEA owes me a day of my life back. I’ve been putting some of their furniture together since this 8am. :angry:
                            johnnyboy @Mykle1
                            • Y Offline
                              yawns Moderator @johnnyboy
                              @johnnyboy
                              No, not custom.css, use the config.js file
                                johnnyboy @yawns
                                    • Y Offline
                                      yawns Moderator
                                      Change layout to ‘vertical’ instead of ‘horizontal’
                                      The part with coloricon looks right
                                      johnnyboyJ 1 Reply Last reply Reply Quote 2
                                        johnnyboy @yawns
