    MMM-doomsDay - The countdown module,
    74 Posts 17 Posters 98.5k Views 16 Watching
      Mykle1 Project Sponsor Module Developer @broberg
      @broberg said in MMM-doomsDay - The countdown module,:
      first versions always have bugs
      Just a follow up. I did the git pull to go back to the original version as you advised. I didn’t disable the module but I did set a new doomsDay for Tuesday. (This was yesterday) The module correctly reported “4 Days Left”. but as of this morning, it still reads "4 Days Left.
        broberg Project Sponsor @Mykle1
        @Mykle1 Finally home, and I believe I have fixed this issue now!
        do a new git pull and it should work in the mornings as well :D
        @illskool You should also do an update on this module! :D
          Thanks bro. Gonna do that right now.
          Ok, I have my test running for tomorrow. The module is correctly displaying “1 Day Left”
              			module: 'MMM-doomsDay',
              			position: 'top_right', // This can be any of the regions, best results in center regions
                  			doomsDay: "2017-02-27 24:00:00", // the end day of the countdown
                  			toWhat: 'Build Bed!', // the title of your countdown event
          				present: 'Get to it!',
          				singular: 'Day Left', // what it should say when it's only one day left, default is `Day Left`
          				plural: 'Days Left', // what it should say when it's more days left, default is `Days Left`
            @broberg
            It seems I’m still having some problems with this. It worked on the last test, and displayed the present: string correctly, but now it’s not working again. Below is my config with the doomsDay set for tomorrow and a screenshot of the display still reporting 2 Days Left
                    			doomsDay: "2017-03-01 24:00:00", // the end day of the countdown
                    			toWhat: 'Doctor Dave Wed', // the title of your countdown event
            				present: 'Doctor Dave 11:30',
              Mykle1 Project Sponsor Module Developer @Mykle1
              @Mykle1
              Somewhere between now and when I posted my previous comment, the module updated to 1 Day left.
                @Mykle1 I think a higher updateInterval may be in order. the 5 Hours set now maybe is a bit to much,
                in the config you can add
                updateInterval: 1 * 3600000,
                To set it to update every hour instead!
                  @broberg
                  Done. I’ll keep you posted. Thanks for your time and effort. :thumbsup_tone1:
                  B Mykle1M 2 Replies Last reply Reply Quote 0
                    @Mykle1 And thank you for all the beta testing! :D
                    Mykle1M 4 Replies Last reply Reply Quote 0
                      My pleasure. Woke up to the module displaying the correct present: entry. Nice!
                        @broberg
                        I hate to be the bearer of bad news, but as of this morning, the module is still not performing correctly. Yesterday, I set a simple test for tomorrow. It correctly reported 2 Days Left. This morning (7:09am) it still reports 2 Days Left. I’ve made only the changes that you have advised.
                        sorry. no screenshot. I’m not at my normal computer
                          @Mykle1
                                  			doomsDay: "2017-03-03 24:00:00", // the end day of the countdown,
                                  			toWhat: 'Pay Day is in', // the title of your countdown event
                          				present: 'Benjamin Pile!',
                          				singular: 'more day!', // what it should say when it's only one day left, default is `Day Left`
                          				plural: 'more days', // what it should say when it's more days left, default is `Days Left`
                            @broberg
                            Just glanced at the mirror and doomsDay is now reporting 1 more day. I don’t know at what time that occurred.
                              @Mykle1
                              Reporting the correct present: message this morning. I’ll now set a week long countdown and see how that goes. I’ll try not to bother you anymore
                                I know I said I would try not to bother you anymore with this but . . .
                                I set doomsDay: "2017-03-15 24:00:00", which is the Ides of March, just as a test. I keep testing because I really want this module to work for me. Well, as of 8:50am today, 2017-03-04. the module is reporting 12 More Days instead of 11. The last test didn’t update the Days Left until late morning, early afternoon. I wouldn’t mind if it was slow in updating by an hour or two but it’s no good to me if it’s 12 hours behind
                                Sorry
                                  @Mykle1 Okay, do a new git pull now. I have altered the method of rounding the numbers, which I should have done from the beginning if I knew better :P
                                  Anyhow. Try the new version!
                                  Mykle1M strawberry 3.141S 2 Replies Last reply Reply Quote 0
                                    I’ll get it right now. Thanks for dealing with this for me.
                                    Did the git pull
                                    I changed my test to the 7th as a 3 day test. I didn’t want to wait till the 15th to see if it was working correctly. It’s reporting 3 Days Left so that’s an improvement right away. I’ll check it in the morning. Thanks again
                                    • strawberry 3.141S Offline
                                      strawberry 3.141 Project Sponsor Module Developer @broberg
                                      @broberg date and time stuff can get really painful, that’s why I’m using moment for those tasks. there are some clever brains that thought about all kind of edge cases etc. you might want to check it out http://momentjs.com/docs/#/displaying/to/
                                      B Y 2 Replies Last reply Reply Quote 1
                                        broberg Project Sponsor @strawberry 3.141
                                        @strawberry-3.141 Yeah I’ve noticed. If this module keeps misbehaving I will look in to the moment.js instead. looka a lot simpler, thanks for the link!
                                        • Y Offline
                                          yawns Moderator @strawberry 3.141
                                          @strawberry-3.141
                                          Absolutely right, moment.js makes life a lot easier when it comes to times and dates.
                                          • SnilleS Offline
                                            Snille Module Developer
                                            Hi there! I just posted a PR to you on github, adding the “passed” text via the config. And also let the “toWhat” event to still be shown when the event has passed (makes more sense i think if you use the “passed” text.) :)
                                            • 2 / 4
