    List Good Monitors To Build With
    19 Posts 12 Posters 31.8k Views 13 Watching
    • AdamMoses-GitHubA
      AdamMoses-GitHub Module Developer
      I thought it might be good to list all the monitors/TVs (with the accompanying URLs) people have had luck building magic mirrors with.
      Ideally these would be monitors that could be put into custom frames, so they’d be light, could have bezels removed without problems, integrated power, etc, but all success stories are welcome!
      Also list any you have tried and didn’t work out so well.
      • AdamMoses-GitHubA
        I guess I should also start.
        I built a great mirror with the ASUS VE248H 24" inch. The bezel came off easily and there is plenty of space around it to put the Pi and other parts.
        https://smile.amazon.com/gp/product/B0043T7FHK/ref=oh_aui_detailpage_o06_s02?ie=UTF8&psc=1
        Also, avoid the 32 inch sceptre X325BV-F, very deep and removing things makes it very tricky to work with.
        /ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
          Cato Module Developer
          @MichMich A database where users could add their experience with hardware would be nice! Hint 😉
          I 1 Reply Last reply Reply Quote 1
          • I
            ihavetenfingers @Cato
            @Cato
            New user here, exactly what I came looking for.
            • O
              ottobot
              I mostly pillage pawnshops and thrift stores for my displays. I take what I can get and make it work. I usually never spend more than $30 for a display unless I’m doing something large for someone.
              1 Reply Last reply Reply Quote -1
              • FlatPepsiF
                FlatPepsi
                This sounds like a noble idea- but the number of monitors/screen out there is staggering.
                It might be more fruitful to have a negative list - known monitors that DON’T work well as MM.
                From what I’ve seen, anything with HDMI works, and with an adapter (which I’m doing), anything with a VGA works. Even the power on/off signals from MMM-PIR-Sensor works great on my humble VGA based, low-res Dell 1908FP.
                AdamMoses-GitHubA 1 Reply Last reply Reply Quote 1
                • AdamMoses-GitHubA
                  AdamMoses-GitHub Module Developer @FlatPepsi
                  @FlatPepsi You are right, flagging which ones NOT to buy may in fact be more useful or at least more effective at saving money.
                    steve23p9835908
                    I’m looking for a monitor right now to use in a PIR setup to save on power. My concern is that the monitor will display “no signal” when the HDMI signal is cut. Should I be worried about this and does anyone know how to get around it?
                    Thanks,
                    Steve
                    T 1 Reply Last reply Reply Quote -1
                    • T
                      Timeeee @steve23p9835908
                      @steve23p9835908
                      @steve23p9835908 said in List Good Monitors To Build With:
                      Thanks,
                      Steve
                      Currently having the exact same problem. I’m currently looking into HDMI CEC stuff, but don’t know if I’m able to fix it with that. It may be the best option not to “cut” HDMI output, but to send the monitor into powersave-mode. I will investigate and let you know if there is some progress!
                      • Y
                        yawns Moderator
                        @Timeeee said in List Good Monitors To Build With:
                        HDMI CEC
                        using https://github.com/Pulse-Eight/libcec indeed works fine, I use the same thing on my pi. It is not yet connected to the PIR sensor, so I cannot provide a out-of-the-box solution for you.
                        One thing you should keep in mind is the “boot delay” the screen needs when you resume out of standby.
                        • T
                          Timeeee @yawns
                          @yawns said in List Good Monitors To Build With:
                          HDMI CEC
                          Thank you dude!
                          Maybe I can get Pulse-Eight running somewhere today. Will hook it up to my PIR as soon as possible :D
                          The delay is fine for me, better then “no signal” ;)
                            steve23p9835908
                            Do all HDMI devices respond to these commands or only particular models? If the latter, can you recommend one? Cheers, Steve
                            • Y
                              yawns Moderator @steve23p9835908
                              I followed these few steps: http://constey.de/2014/10/fernseher-ueber-hdmi-per-raspberry-pi-steuern-cec/
                              I know the instructions are in German, but the commands should be enough.
                              I would say most “smart” screens do, but I don’t have a list of screens which support this. Sorry
                              • T
                                Timeeee @yawns
                                @yawns I think I tried it now for about 5hrs, but Im not able to build the CEC stuff (looks like the how-to is for an older version). Unfortunatly I need some more time to fix those build bugs :(
                                • T
                                  tomster
                                  I can’t tell if my approach would work on the MM-image, but on a RasPi with latest Jessie-image it seems pretty easy:
                                  sudo apt-get install cec-utils
                                  sudo usermod -a -G video [put user triggering the following commands here]
                                  To turn monitor on:
                                  echo on 0 | cec-client -s -d 1
                                  To turn it off:
                                  echo standby 0 | cec-client -s -d 1
                                  Of course it depends on the time your specific monitor will need to come out of deep stand-by. Mine takes 12 secs to respond :-(
                                  But I’ve seen monitors only needing 2 secs…
                                  • cowboysdudeC
                                    I also us ASUS monitors… have had great luck with them!! They seem to stand up to the use!
                                    • jdfraserJ
                                      jdfraser
                                      I’ve had success gutting an old IBM Laptop for its LCD. I ordered this driver board kit off of EBAY and it works great. The ribbon cable is a bit short, but I’ll worry about that when I finally get around to installing the LCD into a mirror / picture frame. My local recycling depot always seems to have a bunch of old laptops being disposed of. I recommend emailing the driver board seller to make sure you get the right one to work with your LCD.
                                        mramitpatel
                                        Great idea! Came here for this information and so far i see:
                                        • Asus
                                        • NOT Spectre
                                        • Buy cheap x from thrift stores
                                        I’m looking to build a mirror that is 28” x 36”. Given LCD prices, it seems like i should buy a TV. Any recommendations on either direction? Looking for a something thin, easy to work with - ie remove bezel, etc, has ports on the right side of display.
                                          steve23p9835908
                                          Thanks for all the advice and after looking around, I feel that the CEC option is the best one but, unfortunately, is out of my budget. I’ve stumbled across this suggestion which looks like a neat (and cheaper way of getting the same effect.
                                          https://forum.magicmirror.builders/topic/2077/pir-sensor-sleep-lcd-monitor
                                          What’s everyone’s thoughts on it? If it wouldn’t work then could you instead connect to the remote control IR input and force standby that way?
