    List Good Monitors To Build With
    19 Posts 12 Posters 30.2k Views 13 Watching
    • I Offline
      ihavetenfingers @Cato
      @Cato
      New user here, exactly what I came looking for.
      • O Offline
        ottobot
        I mostly pillage pawnshops and thrift stores for my displays. I take what I can get and make it work. I usually never spend more than $30 for a display unless I’m doing something large for someone.
        1 Reply Last reply Reply Quote -1
        • FlatPepsiF Offline
          FlatPepsi
          This sounds like a noble idea- but the number of monitors/screen out there is staggering.
          It might be more fruitful to have a negative list - known monitors that DON’T work well as MM.
          From what I’ve seen, anything with HDMI works, and with an adapter (which I’m doing), anything with a VGA works. Even the power on/off signals from MMM-PIR-Sensor works great on my humble VGA based, low-res Dell 1908FP.
          AdamMoses-GitHubA 1 Reply Last reply Reply Quote 1
          • AdamMoses-GitHubA Offline
            AdamMoses-GitHub Module Developer @FlatPepsi
            @FlatPepsi You are right, flagging which ones NOT to buy may in fact be more useful or at least more effective at saving money.
              steve23p9835908
              I’m looking for a monitor right now to use in a PIR setup to save on power. My concern is that the monitor will display “no signal” when the HDMI signal is cut. Should I be worried about this and does anyone know how to get around it?
              Thanks,
              Steve
              T 1 Reply Last reply Reply Quote -1
              • T Offline
                Timeeee @steve23p9835908
                @steve23p9835908
                @steve23p9835908 said in List Good Monitors To Build With:
                Thanks,
                Steve
                Currently having the exact same problem. I’m currently looking into HDMI CEC stuff, but don’t know if I’m able to fix it with that. It may be the best option not to “cut” HDMI output, but to send the monitor into powersave-mode. I will investigate and let you know if there is some progress!
                • yawnsY Offline
                  yawns Moderator
                  @Timeeee said in List Good Monitors To Build With:
                  HDMI CEC
                  using https://github.com/Pulse-Eight/libcec indeed works fine, I use the same thing on my pi. It is not yet connected to the PIR sensor, so I cannot provide a out-of-the-box solution for you.
                  One thing you should keep in mind is the “boot delay” the screen needs when you resume out of standby.
                  • T Offline
                    Timeeee @yawns
                    @yawns said in List Good Monitors To Build With:
                    HDMI CEC
                    Thank you dude!
                    Maybe I can get Pulse-Eight running somewhere today. Will hook it up to my PIR as soon as possible :D
                    The delay is fine for me, better then “no signal” ;)
                      steve23p9835908
                      Do all HDMI devices respond to these commands or only particular models? If the latter, can you recommend one? Cheers, Steve
                      • yawnsY Offline
                        yawns Moderator @steve23p9835908
                        I followed these few steps: http://constey.de/2014/10/fernseher-ueber-hdmi-per-raspberry-pi-steuern-cec/
                        I know the instructions are in German, but the commands should be enough.
                        I would say most “smart” screens do, but I don’t have a list of screens which support this. Sorry
