    Simple Music Player Module
    19 Posts 11 Posters 17.7k Views 9 Watching
    • K Offline
      KirAsh4 Moderator @EoF
      @EoF, correct. That’s why I said, for those who can’t or don’t want to just a touchscreen. They will need a different method to interact with the display.
      • E Offline
        EoF @KirAsh4
        @KirAsh4 Ah okay, yep that is correct. If we had a reliable way to do voice recognition, then I would gladly implement it into this.
        • K Offline
          KirAsh4 Moderator
          Where there’s a will, there’s a way.
          • E Offline
            EoF @KirAsh4
            @KirAsh4 Amen to that
              MechMatt @EoF
              @EoF I saw a guy posted on reddit his magic mirror with voice control (he is using this build of MM). He posted this link for how he set up the voice activation part:
              https://howchoo.com/g/yti5mmq0ntu/add-voice-controls-to-your-raspberry-pi-using-jasper
              don’t know if this helps, but maybe worth looking at. It would definitely be cool to say “MM Play Classic Rock” and it loads up.
              Also, is it possible to, instead of loading all the music on the pi itself, have it stream from a pandora/spotify type site?
              • E Offline
                EoF @MechMatt
                @MechMatt Alright cool I can take a look at it.
                As far as the steaming goes, you may want to check out PtrBld’s module. He has streaming working in his module.
                I may look into building a new module that uses Pandora in the future.
                • N Offline
                  nobiryu @EoF
                  @EoF have you been able to use the reflective film and still retain the touch ability on your screen?
                  If so what kind are you using. I’m looking at using the same type that you can find for car window tinting.
                  • E Offline
                    EoF @nobiryu
                    @nobiryu Hello! Please see this post.
                    https://forum.magicmirror.builders/topic/166/eof-s-touch-screen-magic-mirror-testing-phase
                      denalove
                      I am experiencing a black blank screen after installing the music player code. Here is my code
                      Loading config ...
                      Loading module helpers ...
                      No helper found for module: mm-music-player.
                      All module helpers loaded.
                      Starting server op port 8080 ...
                      Server started ...
                      Starting module: newsfeed
                      Launching application.
                      I’ve only customized the calendar so far, haven’t messed with the other modules just yet. Anyone know what I’m doing wrong?
                      Edit from admin: Please use Markdown on shell output so it is easier to read!
                        denalove @denalove
                        @denalove I got it, found the solution. I added the module to the defaultmodules.js file and it didn’t need to be there.
                        • E Offline
                          EoF @denalove
                          @denalove Happy to hear it, hope you enjoy the module :)
                            dbaler
                            Would you be able to pull files from a server using this module? What would I need to do to change that?
                            • F Offline
                              fabrang
                              @EoF I updated my Magic Mirror on 2.1.1. I wanted to try your modul but after copying it into my modules folder and adding the module in the config, I started the mirror and get a blackscreen. I’ve read that more people got the same issue.
                              Got an Idea what’s the problem? :)
