    Simple Music Player Module
    19 Posts 11 Posters 15.7k Views 9 Watching
    • EoFE Offline
      EoF @MichMich
      @MichMich Yep if you look in the css file in the module, you will see a line at the top that is commented out for displaying the cursor.
      • EoFE Offline
        EoF @KirAsh4
        @KirAsh4 With a touch screen, you wouldn’t need to see the cursor anyways. Which is why I left it as is :)
        Edit: I’m also getting my mirror film today, so I can finally test later whether or not it will work on a capacitive based touch screen.
        I’ll post results!
        KirAsh4K N 2 Replies Last reply Reply Quote 0
        • KirAsh4K Offline
          KirAsh4 Moderator @EoF
          @EoF, correct. That’s why I said, for those who can’t or don’t want to just a touchscreen. They will need a different method to interact with the display.
          EoFE 1 Reply Last reply Reply Quote 0
          • EoFE Offline
            EoF @KirAsh4
            @KirAsh4 Ah okay, yep that is correct. If we had a reliable way to do voice recognition, then I would gladly implement it into this.
            • KirAsh4K Offline
              KirAsh4 Moderator
              Where there’s a will, there’s a way.
              • EoFE Offline
                EoF @KirAsh4
                @KirAsh4 Amen to that
                  MechMatt @EoF
                  @EoF I saw a guy posted on reddit his magic mirror with voice control (he is using this build of MM). He posted this link for how he set up the voice activation part:
                  https://howchoo.com/g/yti5mmq0ntu/add-voice-controls-to-your-raspberry-pi-using-jasper
                  don’t know if this helps, but maybe worth looking at. It would definitely be cool to say “MM Play Classic Rock” and it loads up.
                  Also, is it possible to, instead of loading all the music on the pi itself, have it stream from a pandora/spotify type site?
                  • EoFE Offline
                    EoF @MechMatt
                    @MechMatt Alright cool I can take a look at it.
                    As far as the steaming goes, you may want to check out PtrBld’s module. He has streaming working in his module.
                    I may look into building a new module that uses Pandora in the future.
                    • N Offline
                      nobiryu @EoF
                      @EoF have you been able to use the reflective film and still retain the touch ability on your screen?
                      If so what kind are you using. I’m looking at using the same type that you can find for car window tinting.
                      • EoFE Offline
                        EoF @nobiryu
                        @nobiryu Hello! Please see this post.
                        https://forum.magicmirror.builders/topic/166/eof-s-touch-screen-magic-mirror-testing-phase
