    MMM-MovieInfo
    movietheatre
    27 Posts 11 Posters 23.5k Views 11 Watching
      SilentJbob1680
      Hi, I just recently discovered MM2 & have started on putting it together. This is a fresh install of MM2 & the MovieInfo module however the module is not getting the images.
      This is my config.js
          module: 'MMM-MovieInfo',
          position: 'bottom_left',
      		api_key: ""
      The module shows everything but the image or Poster art. Inspecting the page in Google Chrome results in this appearing:
      GET https://image.tmdb.org/t/p/w185_and_h278_bestv2/undefined 404 ()
      Further examination of the movieinfo.js file shows
      const poster = document.createElement('img');
                  poster.classList.add('poster');
                  poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.posterPath}`;
                  wrapper.appendChild(poster);
      here’s a SS via vnc:
      How can I fix this issue? I know nothing of javascript or programming unfortunately so baby steps in explaining a fix please :)
      Y 2 Replies Last reply
      • Y
        yawns Moderator @SilentJbob1680
        @SilentJbob1680
        For some reason they changed the variable containing the path to the image from posterPath to poster_path
        You could change this
        to this
                    poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.poster_path}`;
        for an immediate fix, or you could wait for strawberry to fix it on github and provide a new version. If you fix it on your own you will need to revert the changes before you can update once strawberry provided the update.
        • strawberry 3.141S
          should be fixed now. thanks for reporting
          • Y
            @SilentJbob1680
            So, please open a terminal on your raspberry, change into the ~/MagicMirror/modules/MMM-MovieInfo folder and do git pull to retrieve the update
            • JacobJ
              Jacob
              Hello.
              I seem to be having issues in setting up the correct config.js. What am I doing wrong? Here is the code I am trying to use.
                                      discover: {
                                              "certification_country": "US",
                                              "certification.lte": "G",
                                              "sort_by": "popularity.desc"
                                      updateInterval: '1080000',
                                      rotateInterval: '180000',
                                      api_key: ' '
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @Jacob
                @Jacob missing comma after discover: {}
                JacobJ 1 Reply Last reply
                • SnilleS
                  Snille Module Developer
                  Hi there! Would there be a possibility to have a config option to set the number of movies to show (as a configurable table)?
                  Also, I read that they now support TV-Shows as well… It would be cool to get that integrated as well :)
                  Ex something like this would be cool…
                    columns: 2,
                    titles: 6,
                    type: {
                      "tv": 1,
                     "movie": 1,
                    discover: {
                      "sort_by": "vote_average.desc"
                  That would give a table that holds 2 columns with 6 rows altering TV-Shows and Movies, descending by votes… 8)
                  • JacobJ
                    Jacob @strawberry 3.141
                    @strawberry-3.141 Thanks for the help. However, it still did not seem to fix it. It’s only the MovieInfo module that seems to be causing the mirror to not load. Would it be possible to show me your MovieInfo config?
                    • strawberry 3.141S
                      @Jacob this config
                          discover: {
                          updateInterval: 1080000,
                          rotateInterval: 180000,
                          api_key: 'PUTYOURAPIKEYHERE'
                      results in
                      • JacobJ
                        @strawberry-3.141 Thanks Strawberry. I just started with a clean config and that seems to have fixed it. I appreciate your help and thank you for the module.
                        Regards,
                        Jacob.
                          SilentJbob1680
                          hey,
                          sorry for taking so long to reply, life found a way to keep me busy! Just wanted to say thanks for the quick reply/fix for my original issue.
                            jeffreyking
                            How do I get the poster in color
                            • strawberry 3.141S
                              strawberry 3.141 Project Sponsor Module Developer @jeffreyking
                              @jeffreyking you need to overwrite the grayscale filter in your custom.css file to 0% https://github.com/fewieden/MMM-MovieInfo/blob/master/MMM-MovieInfo.css#L8-L12
                                jeffreyking
                                Thanks good now
                                  Pade2204
                                  Is there a way to display releasedate? in a specific region :-)
