    MMM-MovieInfo
    movietheatre
    27 Posts 11 Posters 23.0k Views 11 Watching
    • strawberry 3.141S Offline
      Changelog
      • Date manipulation fixed with new dependency
      To update do git pull and npm install
      [card:fewieden/MMM-MovieInfo]
      • N Offline
        number1dan
        nice module. I have this starting hidden and then voice command it to show. I’ve also changed the start and end dates for it to show stuff in cinema now and removed the greyscale from the poster. Good job making this module
          shashank @number1dan
          @number1dan Hi, Module working fine, how to get Indian Movies info
            strawberry 3.141 Project Sponsor Module Developer @shashank
            @shashank as far as i can see this is not supported with this provider to choose a country. i guess you need a different api provider
              There is a new version which has a lot of new possibilities to discover movies
              Thanks to @dr4ke616 who made this happen
                SilentJbob1680
                Hi, I just recently discovered MM2 & have started on putting it together. This is a fresh install of MM2 & the MovieInfo module however the module is not getting the images.
                This is my config.js
                    module: 'MMM-MovieInfo',
                    position: 'bottom_left',
                		api_key: ""
                The module shows everything but the image or Poster art. Inspecting the page in Google Chrome results in this appearing:
                GET https://image.tmdb.org/t/p/w185_and_h278_bestv2/undefined 404 ()
                Further examination of the movieinfo.js file shows
                const poster = document.createElement('img');
                            poster.classList.add('poster');
                            poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.posterPath}`;
                            wrapper.appendChild(poster);
                here’s a SS via vnc:
                How can I fix this issue? I know nothing of javascript or programming unfortunately so baby steps in explaining a fix please :)
                Y 2 Replies Last reply Reply Quote 1
                • Y Offline
                  yawns Moderator @SilentJbob1680
                  @SilentJbob1680
                  For some reason they changed the variable containing the path to the image from posterPath to poster_path
                  You could change this
                  to this
                              poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.poster_path}`;
                  for an immediate fix, or you could wait for strawberry to fix it on github and provide a new version. If you fix it on your own you will need to revert the changes before you can update once strawberry provided the update.
                    should be fixed now. thanks for reporting
                    • Y Offline
                      @SilentJbob1680
                      So, please open a terminal on your raspberry, change into the ~/MagicMirror/modules/MMM-MovieInfo folder and do git pull to retrieve the update
                      • JacobJ Offline
                        Jacob
                        Hello.
                        I seem to be having issues in setting up the correct config.js. What am I doing wrong? Here is the code I am trying to use.
                                                discover: {
                                                        "certification_country": "US",
                                                        "certification.lte": "G",
                                                        "sort_by": "popularity.desc"
                                                updateInterval: '1080000',
                                                rotateInterval: '180000',
                                                api_key: ' '
                          strawberry 3.141 Project Sponsor Module Developer @Jacob
                          @Jacob missing comma after discover: {}
                          JacobJ 1 Reply Last reply Reply Quote 1
                          • SnilleS Offline
                            Snille Module Developer
                            Hi there! Would there be a possibility to have a config option to set the number of movies to show (as a configurable table)?
                            Also, I read that they now support TV-Shows as well… It would be cool to get that integrated as well :)
                            Ex something like this would be cool…
                              columns: 2,
                              titles: 6,
                              type: {
                                "tv": 1,
                               "movie": 1,
                              discover: {
                                "sort_by": "vote_average.desc"
                            That would give a table that holds 2 columns with 6 rows altering TV-Shows and Movies, descending by votes… 8)
                            • JacobJ Offline
                              Jacob @strawberry 3.141
                              @strawberry-3.141 Thanks for the help. However, it still did not seem to fix it. It’s only the MovieInfo module that seems to be causing the mirror to not load. Would it be possible to show me your MovieInfo config?
                                @Jacob this config
                                    discover: {
                                    updateInterval: 1080000,
                                    rotateInterval: 180000,
                                    api_key: 'PUTYOURAPIKEYHERE'
                                results in
                                JacobJ 1 Reply Last reply Reply Quote 0
                                • JacobJ Offline
                                  @strawberry-3.141 Thanks Strawberry. I just started with a clean config and that seems to have fixed it. I appreciate your help and thank you for the module.
                                  Regards,
                                  Jacob.
                                    SilentJbob1680
                                    hey,
                                    sorry for taking so long to reply, life found a way to keep me busy! Just wanted to say thanks for the quick reply/fix for my original issue.
                                      jeffreyking
                                      How do I get the poster in color
                                        strawberry 3.141 Project Sponsor Module Developer @jeffreyking
                                        @jeffreyking you need to overwrite the grayscale filter in your custom.css file to 0% https://github.com/fewieden/MMM-MovieInfo/blob/master/MMM-MovieInfo.css#L8-L12
                                          jeffreyking
                                          Thanks good now
                                            Pade2204
                                            Is there a way to display releasedate? in a specific region :-)
