    MMM-MovieInfo
    movietheatre
    27 Posts 11 Posters 23.4k Views 11 Watching
      balthaz
      Can you had language selection in node_helper.js or config.js
      url: ‘https://api.themoviedb.org/3/discover/movie?primary_release_date.gte=’ + start + ‘&primary_release_date.lte=’ + end + ‘&api_key=’ + this.config.api_key + ‘&language=fr-FR’
      Perfect work, thank you
      • strawberry 3.141S
        sorry forgot about your post
        the problem is that the fields which are not provided in the selected language don’t have anymore a fallback to english (like in previous api versions) and therefore will be empty, that’s why I chose to take allways english, so all data is provided.
        But I can add a config option, so everyone can decide for himself
          balthaz @strawberry 3.141
          @strawberry-3.141 Thanks
          • strawberry 3.141S
            Changelog
            new config options:
            * hide genre
            * hide rating
            * hide plot
            * use language from config instead of default english, this can have missing data from api
              balthaz
              You are the best
              • strawberry 3.141S
                Changelog
                • Date manipulation fixed with new dependency
                To update do git pull and npm install
                [card:fewieden/MMM-MovieInfo]
                • N
                  number1dan
                  nice module. I have this starting hidden and then voice command it to show. I’ve also changed the start and end dates for it to show stuff in cinema now and removed the greyscale from the poster. Good job making this module
                    shashank @number1dan
                    @number1dan Hi, Module working fine, how to get Indian Movies info
                    • strawberry 3.141S
                      strawberry 3.141 Project Sponsor Module Developer @shashank
                      @shashank as far as i can see this is not supported with this provider to choose a country. i guess you need a different api provider
                      • strawberry 3.141S
                        There is a new version which has a lot of new possibilities to discover movies
                        Thanks to @dr4ke616 who made this happen
                          SilentJbob1680
                          Hi, I just recently discovered MM2 & have started on putting it together. This is a fresh install of MM2 & the MovieInfo module however the module is not getting the images.
                          This is my config.js
                              module: 'MMM-MovieInfo',
                              position: 'bottom_left',
                          		api_key: ""
                          The module shows everything but the image or Poster art. Inspecting the page in Google Chrome results in this appearing:
                          GET https://image.tmdb.org/t/p/w185_and_h278_bestv2/undefined 404 ()
                          Further examination of the movieinfo.js file shows
                          const poster = document.createElement('img');
                                      poster.classList.add('poster');
                                      poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.posterPath}`;
                                      wrapper.appendChild(poster);
                          here’s a SS via vnc:
                          How can I fix this issue? I know nothing of javascript or programming unfortunately so baby steps in explaining a fix please :)
                          Y 2 Replies Last reply Reply Quote 1
                          • Y
                            yawns Moderator @SilentJbob1680
                            @SilentJbob1680
                            For some reason they changed the variable containing the path to the image from posterPath to poster_path
                            You could change this
                            to this
                                        poster.src = `https://image.tmdb.org/t/p/w185_and_h278_bestv2/${movie.poster_path}`;
                            for an immediate fix, or you could wait for strawberry to fix it on github and provide a new version. If you fix it on your own you will need to revert the changes before you can update once strawberry provided the update.
                            • strawberry 3.141S
                              should be fixed now. thanks for reporting
                              • Y
                                @SilentJbob1680
                                So, please open a terminal on your raspberry, change into the ~/MagicMirror/modules/MMM-MovieInfo folder and do git pull to retrieve the update
                                • JacobJ
                                  Jacob
                                  Hello.
                                  I seem to be having issues in setting up the correct config.js. What am I doing wrong? Here is the code I am trying to use.
                                                          discover: {
        "certification_country": "US",
        "certification.lte": "G",
        "sort_by": "popularity.desc"
                                                          updateInterval: '1080000',
                                                          rotateInterval: '180000',
                                                          api_key: ' '
                                  • strawberry 3.141S
                                    strawberry 3.141 Project Sponsor Module Developer @Jacob
                                    @Jacob missing comma after discover: {}
                                    JacobJ 1 Reply Last reply Reply Quote 1
                                    • SnilleS
                                      Snille Module Developer
                                      Hi there! Would there be a possibility to have a config option to set the number of movies to show (as a configurable table)?
                                      Also, I read that they now support TV-Shows as well… It would be cool to get that integrated as well :)
                                      Ex something like this would be cool…
                                        columns: 2,
                                        titles: 6,
                                        type: {
                                          "tv": 1,
                                         "movie": 1,
                                        discover: {
                                          "sort_by": "vote_average.desc"
                                      That would give a table that holds 2 columns with 6 rows altering TV-Shows and Movies, descending by votes… 8)
                                      • JacobJ
                                        Jacob @strawberry 3.141
                                        @strawberry-3.141 Thanks for the help. However, it still did not seem to fix it. It’s only the MovieInfo module that seems to be causing the mirror to not load. Would it be possible to show me your MovieInfo config?
                                        • strawberry 3.141S
                                          @Jacob this config
                                              discover: {
                                              updateInterval: 1080000,
                                              rotateInterval: 180000,
                                              api_key: 'PUTYOURAPIKEYHERE'
                                          results in
                                          JacobJ 1 Reply Last reply Reply Quote 0
                                          • JacobJ
                                            @strawberry-3.141 Thanks Strawberry. I just started with a clean config and that seems to have fixed it. I appreciate your help and thank you for the module.
                                            Regards,
                                            Jacob.
