    5 extra points for the WAF :)
    6 Posts 4 Posters 6.5k Views 6 Watching
      dementia
      I want to share with you my first MM build !
      It is based on a 22" monitor (not IPS unfortunately) and a photo frame.
      Currently, I have put a mirror protective film on the glass but … this is not perfect, I can see the some traces of glue when the monitor is running.
      I will move to an acrylic mirror (http://www.signmaterialsdirect.com/3mm-plaskolite-silver-mirror-acrylic-sheet-3mmsilvermea)
      Here is the result:
      Thanks all for the information found here !
      Mykle1M 1 Reply Last reply
      Reply Quote 2
        dementia
        Modules installed:
        • trafic information from home to work
        • RSS feed
        • new email notification
        • calendar
        • weather
        The monthly calendar view comes from an iFrame and dakboard.com
        For that I have had to start MagicMirror in server mode and open the url through Chromium cause dakboard needs to be loged on …
        • Mykle1M
          Mykle1 Project Sponsor Module Developer @dementia
          @dementia said in 5 extra points for the WAF :):
          Looks good! :thumbsup_tone2:
            d3r
            @dementia Looks good.
            I like that monthly iframe calendar. I’ll check that website to see if I can get a weekly iframe calendar.
            D 1 Reply Last reply
              dementia @d3r
              @d3r this is the only way I found to have this kind of view !
                chris1971
                can you explain a noob a little bit more in detail how to implement the Dakboard calandar into the MM?
                I really like your setup,
                Regards, Chris
