    MMM-FRITZ-Box-Callmonitor
    99 Posts 27 Posters 132.5k Views 26 Watching
      Jopyth Moderator @boardnick
      @boardnick From your logs I read, that lxml is not installed, did you execute step 3 of the installation?
      Edit: Did anything during execution of this command go wrong? sudo apt-get install python-dev libxml2-dev libxslt1-dev zlib1g-dev && sudo pip install fritzconnection
      • boardnickB
        boardnick
        @Jopyth Thank you for your respond!
        Yes, i executed step 3 of the installation. As far as a remember nothing did go wrong.
        Hoping that i did not damage anything i executed your listed command one by one once again:
        –> already latest version
        sudo apt-get install libxml2-dev
        sudo apt-get install libxslt1-dev
        sudo apt-get install zlib1g-dev
        –> Requirement already satisfied (use --upgrade to upgrade): fritzconnection in /usr/local/lib/python2.7/dist-packages
        Cleaning up…
        So for the last command i additionally executed
        sudo pip install fritzconnection --upgrade
        –> Requirement already up-to-date: fritzconnection in /usr/local/lib/python2.7/dist-packages
        Cleaning up…
        J 1 Reply Last reply
          @boardnick That is strange. Can you try calling the python connection script directly? For example, replace your password, user and IP in this command python fritz_access.py -p passwd -u user -i 192.168.FRITZ.BOX? Needs to be called from the MMM-FRITZ-Box-Callmonitor directory.
          • boardnickB
            boardnick
            @Jopyth i tried calling it directly and get the same result:
            0_1485275096473_upload-ad5969e4-3d7d-42b8-80c5-6f033ec526f4
              @boardnick Well the good news in that case is: You just need to fix this error, and it should work fine. Does this work? Or any of the things google spits out? If yes, please let me know, maybe the current way of installing lxml is not the best one.
              • boardnickB
                boardnick
                @Jopyth i’m trying to test the recommended links this weekend and give you a feedback afterwards.
                Thank you so far!
                • boardnickB
                  boardnick
                  Hi @Jopyth, Hi all,
                  good news: It works after installing python-lxml as follows:
                  sudo apt-get install python-lxml
                  Thank you very much for your support and have a nice weekend!
                    Photon2000
                    Hi all,
                    I have installed MagicMirror and the MMM-FRITZ-Box-Callmonitor two times from scratch and get the same error from the MMM-FRITZ-Box-Callmonitor:
                    I’ve followd the thread and tried finally:
                    “python fritz_access.py -p password -u user -i ip-of-fritzbox”
                    and get the following error message:
                    File “fritz_access.py”, line 77, in
                    main(args)
                    File “fritz_access.py”, line 63, in main
                    handle.download_phone_book()
                    File “fritz_access.py”, line 22, in download_phone_book
                    result = self.fc.call_action(“X_AVM-DE_OnTel”, “GetPhonebookList”)
                    File “/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py”, line 405, in call_action
                    action = self._get_action(service_name, action_name)
                    File “/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py”, line 378, in _get_action
                    raise ServiceError('Unknown Service: ’ + service_name)
                    fritzconnection.fritzconnection.ServiceError: Unknown Service: X_AVM-DE_OnTel:1
                    Do you have any ideas?
                      Jopyth Moderator @Photon2000
                      @Photon2000 Can you try to execute this: python -c "import fritzconnection as fc; fc.print_api(password='PWD')" and have a look at your model and OS version? Maybe they changed something in the API, or you have an older version?
                        Photon2000
                        Thx for fast reply!
                        sudo python -c “import fritzconnection as fc; fc.print_api(password=‘PWD’)”
                        gives:
                        FritzConnection:
                        version: 0.6
                        model: None
                        FritzBox API:
                        and
                        uname -a
                        Linux Aragorn 3.19.0-26-generic #28~14.04.1-Ubuntu SMP Wed Aug 12 14:09:17 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
                        • H
                          Hellfire666
                          I have the same problem:
                          no recent calls with “unknown error” in brackets like Photon2000, when I do
                          python fritz_access.py -p pwd -u user -i 192.168.2.1 (the IP of my fritz.box) I get:
                          main(args)
                          File “/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py”, line 406, in call_action
                          return action.execute(**kwargs)
                          File “/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py”, line 130, in execute
                          result = self.parse_response(response.content)
                          File “/usr/local/lib/python2.7/dist-packages/fritzconnection/fritzconnection.py”, line 142, in parse_response
                          root = etree.fromstring(response)
                          File “src/lxml/lxml.etree.pyx”, line 3213, in lxml.etree.fromstring (src/lxml/lxml.etree.c:79010)
                          File “src/lxml/parser.pxi”, line 1848, in lxml.etree._parseMemoryDocument (src/lxml/lxml.etree.c:118341)
                          File “src/lxml/parser.pxi”, line 1736, in lxml.etree._parseDoc (src/lxml/lxml.etree.c:117021)
                          File “src/lxml/parser.pxi”, line 1102, in lxml.etree._BaseParser._parseDoc (src/lxml/lxml.etree.c:111265)
                          File “src/lxml/parser.pxi”, line 595, in lxml.etree._ParserContext._handleParseResultDoc (src/lxml/lxml.etree.c:105109)
                          File “src/lxml/parser.pxi”, line 706, in lxml.etree._handleParseResult (src/lxml/lxml.etree.c:106817)
                          File “src/lxml/parser.pxi”, line 635, in lxml.etree._raiseParseError (src/lxml/lxml.etree.c:105671)
                          File “”, line 1
                          lxml.etree.XMLSyntaxError: Opening and ending tag mismatch: HR line 1 and BODY, line 1, column 146
                          Any chance this can be fixed?
                          I allready tried all of the above…
                          • H
                            Hellfire666
                            my problem has vanished. I have reinstalled the module and did
                            npm install
                            twice, now it is working.
                              domi256
                              Hey i got a Problem with this module,
                              I installed it from the instructions, and added this to config.js:
                              			module: "MMM-FRITZ-Box-Callmonitor",
                              			header: "Recent calls",
                              				username: "raspi",
                              				password: "domi1234",
                              				maximumCallDistance: 7200,
                              				showContactsStatus: true
                              If i want to start it via npm start, i get an error Message like this:
                              pi@mirror:~/MagicMirror $ npm start
                              > magicmirror@2.1.1 start /home/pi/MagicMirror
                              > sh run-start.sh
                              Starting MagicMirror: v2.1.1
                              Loading config ...
                              Loading module helpers ...
                              Module helper loaded: ping
                              WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'node-fritzbox-callmonitor'
                              App threw an error during load
                                  at Module._resolveFilename (module.js:470:15)
                                  at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:35:12)
                                  at Function.Module._load (module.js:418:25)
                                  at Module.require (module.js:498:17)
                                  at require (internal/module.js:20:19)
                                  at Object. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:4:21)
                                  at Object. (/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/node_helper.js:259:3)
                                  at Module._compile (module.js:571:32)
                                  at Object.Module._extensions..js (module.js:580:10)
                                  at Module.load (module.js:488:32)
                              { Error: Cannot find module 'node-fritzbox-callmonitor'
                                  at Module.load (module.js:488:32) code: 'MODULE_NOT_FOUND' }
                              Launching application.
                              Can someone help me please? :(
                              Thank you verry much
                              strawberry 3.141S yawnsY 2 Replies Last reply
                              • strawberry 3.141S
                                strawberry 3.141 Project Sponsor Module Developer @domi256
                                @domi256 looks like you didnt install the dependencies with npm install in /home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor
                                • yawnsY
                                  yawns Moderator @domi256
                                  • garblefluxG
                                    garbleflux Project Sponsor @Jopyth
                                    @Jopyth I also have trouble with this module: Once I get a call, a window pops up and shows me the number. So far all o.k. But the recent call list is still empty.
                                    Maybe it depends on my Fritz!box configuration: I use for security a password to
                                    have access to the Fritz!box. in the configuration options for the MMM-Callmonitor I do not see an command to handle this password. Is it necessary to remove it?
                                    Regards Mike
                                    Sandy2503S 1 Reply Last reply
                                    • Sandy2503S
                                      Sandy2503 @garbleflux
                                      @garbleflux - try to create a useraccount on the fritzbox (with name and password). ths works very well with my 7490 …
                                      garblefluxG 1 Reply Last reply
                                      • garblefluxG
                                        garbleflux Project Sponsor @Sandy2503
                                        @Sandy2503 thank you for your kind reply. I already did create a useraccount. But with this data (User: raspi, password: xxxxxxxx) I do not have an access. So it is neccessary to disable the general Fritz!box password? Regards Mike
                                        • Sandy2503S
                                          Sandy2503
                                          Have you edit the fritz.box config ? I mean like in post #1.
                                            rf0620
                                            Like some other people here I wasn’t able to to read out the content of any phonebook from fritzbox. Only phone numbers were presented.
                                            Also the command line didn’t work:
                                            main(args)
                                            Today I found a very simple answer: The used protocol TR-064 wasn’t activated on my fritz box!
                                            According to this site I had to enable support for it. It worked for my FBF 7390 immediately. This setting has a different location than user mangament on current firmware versions.
                                            2 1 Reply Last reply
                                            Reply Quote 2
                                            • 3 / 5
