How do I make my 27" monitor (smartmirror) touchscreen *using raspberry Pi*
Just wondering how to make my smart mirror project touchscreen. Ive looked at touchscreen overlays but they are expensive and dont even say whether they are compatible with raspberry pi. If someone could point me in the right direction that’d be good
@broberg Oh sweet! Whats the price range on Ir panels that are 27" because the one i found came to $240 wondering if there’s any cheaper options
@TheMexicoon Easiest way? Probably an IR-Frame since projected capacitive touch foils usually don’t work through the mirror coating.
I suppose that the one way mirror film applied to a normal piece of glass could work with the touch foils since it’s less likely that the mirror film has a metallic coating that would interfere with the touch foil. But it’s just a guess, Haven’t tried it myself.
This post is deleted! -
@broberg so would this https://www.aliexpress.com/store/product/27-inch-dual-touch-USB-IR-touch-screen-panel-IR-dual-touch-frame-infrared-touch-screen/1542564_32352720770.html
Be compatible with a ACER V273HL Monitor and raspberry pi 3 model b
@TheMexicoon The IR-frame mounts on top of the mirror frame, so it doesn’t really care what type of monitor you use, as long as the size of the frame is the same as the monitor. Most of the IR-frames for sale out there works on Linux, so in theory almost all IR-frames will work with the Raspberry Pi
@johnnyboy pointed however out that you probably only get single-touch on linux, atleast I think it was Johnny
@broberg how does the coding work because i was planning on using Android os on the Pi would that be a viable option? Im open to use linux but would prefer android
@TheMexicoon Should work on android as well as long as the android OS and IR-Frame support each others.
The frame should just be recognized and used as any other input (like mouse or keyboard), no coding should be necessary.
@TheMexicoon That I don’t know, Maybe somebody else will chime in with some better information!
@broberg Alright thanks for your help man, appreciate it
I don’t understand I just got a 32" IR Frame from AliExpress for 111.00 that included shipping…
I’m here to tell you it works perfectly!!
Go here: Store name: NCOOVERLAYFOIL TouchScreen Store On AliExpress these guys are awesome!!
@cowboysdude i found the store, its $137 for 32" 6 point touch which comes to $180 dollars (aud)
@TheMexicoon said in How do I make my 27" monitor (smartmirror) touchscreen *using raspberry Pi*:
Wow… that’s alot…
@TheMexicoon when I used to live in Australia everything was 2-3 times more expensive than elsewhere, but also the minimum salary was about 21$/hour so i think this is still a valuable price
@strawberry-3.141 so you think this is the cheapest im going to find???
@TheMexicoon not saying that, but you probably can find the cheapest on aliexpress. my old roommate bought nearly everything there and sometimes even imported containers :D
@strawberry-3.141 found this ???https://www.aliexpress.com/item/27-Inch-16-9-Wide-Multi-Touch-IR-Infrared-Touch-Screen-Frame-Overlay-Kit-2-4/32360101915.html?spm=2114.01010208.3.385.SfrBFY&ws_ab_test=searchweb0_0,searchweb201602_2_10065_10130_10068_433_434_10136_10137_10138_10060_10131_10132_10062_10133_10141_10056_10140_126_10055_10054_10059_10099_10103_10102_10096_10052_10053_10050_10107_10142_10051_10106_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_10078_10079_10073_10070_10122_10123_10124,searchweb201603_1,afswitch_1,ppcSwitch_5,single_sort_0_price_asc&btsid=8984b02b-d7da-48f7-aa17-07e18aa40e7d&algo_expid=1f5fae33-a294-42bf-bc8a-bd6938b6e93c-46&algo_pvid=1f5fae33-a294-42bf-bc8a-bd6938b6e93c
