    Calendar Module: Multiple Icons.
    21 Posts 6 Posters 16.3k Views 6 Watching
    • strawberry 3.141S
      strawberry 3.141 Project Sponsor Module Developer @Richard238
      @Richard238 in my oppinion there is no easy and clean solution for that without modyfing the code
      in the next update there is at least the possibility to colorize every calendar differently
      johnnyboyJ 1 Reply Last reply
      • johnnyboyJ
        johnnyboy @strawberry 3.141
        • johnnyboyJ
          johnnyboy @Richard238
            Richard238
            Sure, it’s in /home/pi/MagicMirror/css/custom.css
             * Changes to this files will be ignored by GIT. *
             body {
             .fa.fa-calendar-check-o {
              color: #00d2ff; /* Blue */
             .fa.fa-trash-o  {
              color: #C97F7F; /* Brown */
            johnnyboyJ strawberry 3.141S 2 Replies Last reply
            • johnnyboyJ
              • strawberry 3.141S
                @Richard238 https://github.com/MichMich/MagicMirror/pull/779
                johnnyboyJ R 2 Replies Last reply
                • johnnyboyJ
                  • strawberry 3.141S
                    strawberry 3.141 Project Sponsor Module Developer @johnnyboy
                    @johnnyboy There is a css trick you probably didn’t know about, but will blow your mind :D
                    there is only one trash can icon in fontawesome, so how can we use it but colorize it differently for different trash types.
                    In germany, at least in my area, paper is blue, plastic is yellow, biowaste is brown and rest is black.
                    this is a working example https://jsfiddle.net/a8p7snpd/4/ you just need some icons that you never will use in the calendar module like car, truck and cab
                      Richard238 @strawberry 3.141
                      @strawberry-3.141 What do I do with that, how do I use it?
                      Thanks.
                      • cowboysdudeC
                        strawberry taught me how to do this he said:
                        “there two ways to make a truck to a trash can 1. you take my css 2. you crash the truck into a wall :D”
                        • strawberry 3.141S
                          @Richard238 you have to wait until it gets merged into the code base or you switch to my fork, but i wouldnt recommend that
                          • johnnyboyJ
                            • strawberry 3.141S
                              changes got merged and can be used in the develop branch or you have to wait until the new version gets deployed
                              alt text
                              Mykle1M 1 Reply Last reply
                              • Mykle1M
                                Mykle1 Project Sponsor Module Developer @strawberry 3.141
                                @strawberry-3.141 said in Calendar Module: Multiple Icons.:
                                Will I be able to choose NO ICON?
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @Mykle1
                                  @Mykle1 there is a default symbol, but you could try to cheat and define symbol as an empty string. cant test it atm.
                                  • Mykle1M
                                    @strawberry-3.141
                                    Ok, thank you
