    Pilkington mirror and Silicone
    22 Posts 3 Posters 13.6k Views 3 Watching
    • johnnyboyJ
      johnnyboy @broberg
        broberg Project Sponsor @johnnyboy
        @johnnyboy if you do a good seem on the outside and grind it down flush I think it still would have enough bond left to hold the frame together.
        I’m going all epoxy glue and hope it holds, my 120x60cm 6mm mirror also has a bit of weight :D
        I went with a 15x40mm aluminium L profile, inside that I’ll glue a wooden mdf frame to the profiles so I’m counting on that the amount of glued surface will make it hold together.
        I have the profiles glued to the mirror as of now, and hopefully I will have the mdf frame made and bonded today.
        Here is a potato picture of the frame now :
        Quick note, I’m not going to apply glue on the side with the coating since I was told by my Glass guy that some coating and some glues doesn’t like each other, didn’t want to risk it. Even if the coated side have slightly better reflection propertys.
        johnnyboyJ 2 Replies Last reply Reply Quote 1
        • johnnyboyJ
          johnnyboy @broberg
          • johnnyboyJ
            johnnyboy @broberg
              @johnnyboy the frame is beeing glued to the aluminium right now, used a new glue and it takes for ever to cure.
              My plan is to go over the aluminium with some 400-800-1200 wet sanding and then a polish wheel to get it somewhat uniform in surface texture.
              It scratches fairly easy, as aluminium does, I’ve managed to make some nicks to it miself during assembly.
              johnnyboyJ 1 Reply Last reply Reply Quote 0
              • johnnyboyJ
                johnnyboy @broberg
                  @johnnyboy So what I settled for was to start with 400 wet to get rid of the worst scratches and then went over it all with 800 wet, and I’m probably leaving it there, it got that more brushed look which will fit in with the stainless sink below it. But If you want it more shiny this is the way to go and then 1200 wet and a polish after that!
                  my MDF frame is 16mm thick and 46mm deep, and as you can see the screen fixture is pretty basic (layed it all down and glued in some spare MDF bits around the screen) But this way it will stay fixed and I can still remove the entire monitor with ease for installation in the house later on.
                  I’m fixing the glass and the frame to the box with 2pc 50cm piano-hinges at the top and several magnets at the bottom (so the mirror will be easy to open to access the PI and everything else.
                  I used 2 comp Epoxy to fix the aluminium to the glass, didn’t get it perfect so I also filled the tiny gaps in the corners with some “liquid metal”, which basically is polyester and aluminium dust. Still a color difference, but at least no gaps.
                  I then used a glue called BT Multibond, which is a flexible glue, more like silicone, leaves a rubbery feel when cured. To fix the MDF frame to the glass and aluminium.
                  Mykle1M johnnyboyJ 2 Replies Last reply Reply Quote 0
                  • Mykle1M
                    Mykle1 Project Sponsor Module Developer @broberg
                    @broberg Why is there a motorcycle in your living room? ;-)
                      broberg Project Sponsor @Mykle1
                      @Mykle1 Because the garage is full with other motorcycles … ;)
                      • johnnyboyJ
                        johnnyboy @broberg
                          @johnnyboy I have sawn out some thin 14x2mm strips of the same material as the box that will be glued around the edges, so the MDF won’t be visible (it’s the wood you can see in the reflection of the mirror).
                          The first thought was to make the entire frame of it, but once cut of from the board the frame parts warped a lot. :P
                          Like this :
                          Nah, My glass is like 3% light transmission and 57% reflection, so it’s not ideal for bright environments. Have to make everything on the display 40% larger to get readable text.
                          Every man should have a bike inside, it’s classy :D
                          (my kitchen table is the work bench, the last 2 years I have had my gpz900R engine in pieces laying on top of it :D )
                          • johnnyboyJ
                            johnnyboy @broberg
