MMM-Fuel
@sindbad6 you closed your pull request and deleted the branch so there is no possibility to merge your changes
@strawberry-3.141 That’s what I was afraid of. I will try to correct it.
Changelog v1.1.0
- API provider development Guide.
- API provider
spritpreisrechner.at
. - Disabled markdownlint rule
MD026
(no-trailing-punctuation) - Disabled eslint rule
no-console
- Documentation
- Doclets.io integration
- Contributing guidelines
- Issue template
- Pull request template
[card:fewieden/MMM-Fuel]
Anyone considered adding support of multiple locations? Useful for example for commuters to lookup prices at start and destination (and/or somewhere in between) of their daily way to work.
hi strawberry. Absolut nice work, I use it daily! One question: How did you get the in the example (Cheapest Gas Stations) all the text in the listing left justified?
@garbleflux if you scroll down there is module configuration https://github.com/MichMich/MagicMirror#configuration you can add the class
align-left
Changelog v1.1.1
- Disabled markdownlint rule MD024 (no-duplicate-header)
- Config option toFixed to show only 2 decimals for the price.
- Coordinate.to() throws exception if start point is not set.
Upcoming release v1.2.0
https://github.com/fewieden/MMM-Fuel/projects/1[card:fewieden/MMM-Fuel]
Hi @strawberry-3.141,
thanks for creating this great module! Would any of the following be possible?- hide the distance column
- show the prices of pre-selected gas stations
- show e.g. the three cheapest plus some pre-selected gas stations
@rudibarani you can hide the distance column with css in custom.css, the other points are currently not possible
Hi and Thanks for this module.
I’ve only one Problem: I did not get the column with the price ;)
It seems all other things are okay.
What can i do/check?
Thanks a lot for every tip :)
