Last time connected to Net
(For debugging purposes)
I have found the my (WiFi only) MM sometimes “falls off the net” - which means that the info it displays is outdated.
It still display stuff, but there seems no EASY way for me to tell what happened as far as I can tell. I just notice that my calendar is outdated; that my Wunderlist is old; that my commute times don’t seem right…
Then I try pinging/SSHing & fail. Reboot time.So I am requesting a (small) module that states “last time connected” so I have an indication if things are wrong. Or I’d like someone to tell me how to deal with this. Or (better still) the module would check for WiFi signal & then respawn a PM2 process.
You mean something like this? https://github.com/CFenner/MagicMirror-Ping-Module
@Ashidian Yup. Thx.
Mykle1 Project Sponsor Module Developerlast edited by Mykle1 Mar 28, 2017, 8:42 PM Mar 28, 2017, 8:42 PM
Have you done this?
https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#disable-wifi-power-save(Snip)
Disable WiFi Power Save
Edit /etc/modprobe.d/8192cu.conf
sudo nano /etc/modprobe.d/8192cu.conf
Add the following linesDisable power saving
options 8192cu rtw_power_mgnt=0 rtw_enusbss=1 rtw_ips_mode=1
For Raspberry Pi 3
Edit /etc/network/interfacessudo nano /etc/network/interfaces
Add the following line under the wlan0 sectionwireless-power off
Reboot your PIsudo reboot
@Mykle1 I did - I also run cron jobs to turn the monitor off & on (night & day). I just have “interesting” WiFi, so monitoring is not a bad idea. Guess I really should run a ping of the MM from somewhere else & send myself a txt if it goes down. I’ll putter around with IFTTT…
