Last time connected to Net
5 Posts 3 Posters 2.4k Views 2 Watching
    amanzimdwini
    (For debugging purposes)
    I have found the my (WiFi only) MM sometimes “falls off the net” - which means that the info it displays is outdated.
    It still display stuff, but there seems no EASY way for me to tell what happened as far as I can tell. I just notice that my calendar is outdated; that my Wunderlist is old; that my commute times don’t seem right…
    Then I try pinging/SSHing & fail. Reboot time.
    So I am requesting a (small) module that states “last time connected” so I have an indication if things are wrong. Or I’d like someone to tell me how to deal with this. Or (better still) the module would check for WiFi signal & then respawn a PM2 process.
    M 1 Reply Last reply Mar 28, 2017, 8:42 PM Reply Quote 0
      Ashidian
      You mean something like this? https://github.com/CFenner/MagicMirror-Ping-Module
      A 1 Reply Last reply Mar 28, 2017, 8:34 PM Reply Quote 0
        amanzimdwini @Ashidian
        @Ashidian Yup. Thx.
          Mykle1 Project Sponsor Module Developer @amanzimdwini
          @amanzimdwini
          Have you done this?
          https://github.com/MichMich/MagicMirror/wiki/Configuring-the-Raspberry-Pi#disable-wifi-power-save
          (Snip)
          Disable WiFi Power Save
          Edit /etc/modprobe.d/8192cu.conf
          sudo nano /etc/modprobe.d/8192cu.conf
          Add the following lines
          Disable power saving
          options 8192cu rtw_power_mgnt=0 rtw_enusbss=1 rtw_ips_mode=1
          For Raspberry Pi 3
          Edit /etc/network/interfaces
          sudo nano /etc/network/interfaces
          Add the following line under the wlan0 section
          wireless-power off
          Reboot your PI
          sudo reboot
          A 1 Reply Last reply Mar 28, 2017, 9:28 PM Reply Quote 0
            amanzimdwini @Mykle1
            @Mykle1 I did - I also run cron jobs to turn the monitor off & on (night & day). I just have “interesting” WiFi, so monitoring is not a bad idea. Guess I really should run a ping of the MM from somewhere else & send myself a txt if it goes down. I’ll putter around with IFTTT…
