Bonding glass and MDF
12 Posts 5 Posters 8.0k Views 4 Watching
  • O Offline
    ontheway16
    Hello all, I am planning to build my first magic mirror but unfortunately all build examples are based on a wooden frame. My magic mirror is planned as frameless. I want to someway glue a mdf backplate to twoway mirror, and want to hear your opinions about glue choices.
    My first idea is using a 3m double sided tape (black). Do you know/advise any other options to hang 140cm x 50 cm mirror to wall, without using an outer frame? Thanks,
    Alp
    J 1 Reply Last reply Apr 4, 2017, 10:34 PM Reply Quote 0
      johnnyboy @ontheway16
      • O Offline
        ontheway16
        I am afraid I have no other choices. Was looking around and found these;
        http://www.doityourself.com/stry/how-to-glue-wood-to-glass
        http://audiokarma.org/forums/index.php?threads/best-way-to-glue-glass-to-mdf.329230/
        http://www.woodweb.com/knowledge_base/Gluing_Painted_Glass_to_Wood_or_MDF.html
        J B 2 Replies Last reply Apr 5, 2017, 10:45 AM Reply Quote 0
            broberg Project Sponsor @ontheway16
            @ontheway16 as @johnnyboy mentioned, the 2 way mirrors often has the mirror coating on one side which can react to the glue and/or seperate from the glass. If you’re not sure do consult the manufacturer of the mirror you are using!
            O 1 Reply Last reply Apr 6, 2017, 4:48 PM Reply Quote 0
            • O Offline
              ontheway16 @broberg
              @broberg @johnnyboy Thanks for the replies, I will ask the manufacturer whether its a first or second surface mirror (https://spectrumscientifics.wordpress.com/2011/07/13/first-and-second-surface-mirrors/)
              Best thing I can do will be testing glue alternatives on a piece of 2way mirror I am going to use, I think…
              • G Offline
                Goldjunge_Chriz
                There are special double-sided mounting adhesive tapes for different material combinations. For example, I built an aluminum frame and glued the glass with a glass / aluminum strip from Würth. Holds bombproof and gives no problems with my mirror and the surface. ;)
                Y 1 Reply Last reply Apr 6, 2017, 7:49 PM Reply Quote 0
                • Y Offline
                  yawns Moderator @Goldjunge_Chriz
                  @Goldjunge_Chriz
                  So your (and also mine) mirror glass can be glued to a surface?
                  G 1 Reply Last reply Apr 6, 2017, 7:58 PM Reply Quote 0
                  • G Offline
                    Goldjunge_Chriz @yawns
                    @yawns
                    Absolutely ;) you can see that on my pictures too :)
                    O Y 2 Replies Last reply Apr 6, 2017, 10:26 PM Reply Quote 1
                    • O Offline
                      ontheway16 @Goldjunge_Chriz
                      @Goldjunge_Chriz said in Bonding glass and MDF:
                      @yawns
                      Can you please post a link about it?
                      Is it the tape below?
                      https://eshop.wuerth.de/Product-categories/Mirror-adhesive-tape/14013004040301.cyid/1401.cgid/en/US/EUR/
                      G 1 Reply Last reply Apr 7, 2017, 7:21 AM Reply Quote 0
