Compliments setup
In config.js
{ module: 'compliments', position: 'lower_third' config: { anytime: [ "Compliment 1", "Compliment 2", "Compliment 3" ] }, { module: 'currentweather',Gives the “Please create a config file” error
Take out the. . .
config: { anytime: [ "Compliment 1", "Compliment 2", "Compliment 3" ]. . .lines, and it’s OK.
What’s it not liking in there?
@Richard238 said in Compliments setup:
The , (comma) after ‘lower_third’. It should look like this
{ module: 'compliments', position: 'lower_third', config: { anytime: [ "Compliment 1", "Compliment 2", "Compliment 3" ] }, -
Thanks, it was that, and a missing } close curly bracket.
Oh! Yes, I missed that one. Good catch on your part. So lets fix it in case anyone else looks at this for help. The correct entry would be this:
{ module: 'compliments', position: 'lower_third', config: { anytime: [ "Compliment 1", "Compliment 2", "Compliment 3" ] } },That’s better.
Whilst the config.js now loads, it’s not showing the new, replacement compliments.
I’ve restarted NPM, no change.
I’ve powered Pi off & on, no change.
{ module: 'compliments', position: 'lower_third', config: { anytime: [ "Compliment 1", "Compliment 2", "Compliment 3" ], morning: [ "morning Compliment 1", "morning Compliment 2", "morning Compliment 3" ], afternoon: [ "afternoon Compliment 1", "afternoon Compliment 2", "afternoon Compliment 3" ], evening: [ "evening Compliment 1", "evening Compliment 2", "evening Compliment 3" ] } },try this please. I do remember there was something like “all 3 cases need to exist, otherwise it takes default values for this”
Ohhh, interesting. I’ll have a go and report back later.
Thank you. -
No difference, still uses default compliments:
config: { anytime: [ "Compliment 1", "Compliment 2", "Compliment 3" ], morning: [ "morning Compliment 1", "morning Compliment 2", "morning Compliment 3" ], afternoon: [ "afternoon Compliment 1", "afternoon Compliment 2", "afternoon Compliment 3" ], evening: [ "evening Compliment 1", "evening Compliment 2", "evening Compliment 3" ] } }, -
Changing it to remoteFile, as described here, it works.
Well, only after it’s still displayed all the default messages.
Still not picking up different compliments:
{ module: 'compliments', position: 'lower_third', config: { anytime: [ "Hey!" ], morning: [ "Good morning, handsome!", "Enjoy your day!", "How was your sleep?" ], afternoon: [ "Hello, beauty!", "You look sexy!", "Looking good today!" ], evening: [ "Wow!", "You!", "Hi!" ] }, updateInterval: 30000, remoteFile: null, fadeSpeed: 4000 /*config: { remoteFile: 'compliments.json' }*/ }, -
Another day, still no change, compliments ignoring whatever is in config.js.
Thank you.
Do you edit the config.js?
Well… you could be a outlaw and edit the “~/MagicMirror/modules/default/compliments/compliments.js”.
I’ve done that before and it works. But beware of typos. Make a backup! :) -
That’s what I have done now, but it is only a fudge, a workaround.
What’s the problem with using config.js to make changes to the compliments module, why doesn’t it work?
@Richard238 I live with the idea that “if it work, dont ask why”.
So I can’t explain why config.js dont work.
