    Changing Module Display Width
    24 Posts 6 Posters 26.7k Views 6 Watching
    • johnnyboyJ
      johnnyboy @broberg
      @broberg
      Ah, ok… I was jumping ahead of myself there… so I will try
      .MMM-WunderGround {
          width : 200px;
      200px; or whatever looks good.
      Thanks again.
      johnnyboyJ 1 Reply Last reply
      • johnnyboyJ
        johnnyboy @johnnyboy
        I changed mines to 250px as that was about maxed out or else it would move the large Moon icon onto top bar and would become 1/3 of its original size and not look right, or look good… so I’m pretty happy at that.
        However, I thought to do the same thing to the calendar that’s directly opposite, on the top right…to keep the aspect look… Nope! It wont budge for some reason?
        Side effect now is a slight 5 - 7 second load time to WunderGround, Calendar, and News feed on bottom bar… No idea if this is linked or no?No effect at all on Compliments or SimpleLogo.
        .Module_calendar {
        width : 250px;
        No idea if this is relevant, but should I have included the calendar header Uk Holidays? My calendar is also linked to Google Calendar so no idea if that could be a reason either why it wont allow width to be adjusted, but thought to mention
        brobergB 1 Reply Last reply
        • brobergB
          broberg Project Sponsor @johnnyboy
          @johnnyboy I think it should be just .calendar not .Module_calendar
          • johnnyboyJ
            johnnyboy @broberg
            @broberg
            ok will try that now… Yes that did it… I didn’t know not to include .Module there… Thought they all had the same command, apart from MMM
              deadherring
              I have my MM configured vertically and a lot of the calendar entries get cut off. I’m trying to widen the calendar.
              This is what I’ve added to custom.css but I’m not seeing any change. (sorry, I’m not sure how to make the code show up in a special way the way others do)
              body {
              .MMM-calendar {
              width : 350px;
              Can someone point me in the right direction in terms of what I’m doing wrong?
              Thanks,
              Nathan
              • brobergB
                broberg Project Sponsor @deadherring
                @deadherring
                .calendar {
                width : 350px;
                It’s not supposed to be inside the body{} and since it is a default/stock module it doesn’t use the MMM prefix like other modules does so the class name of the module is just .calendar
                  deadherring
                  Thanks @broberg, that worked, I can see that changes I make are taking effect now.
                  I set the calendar to 450px. However, as you can see from this
                  picture, the date text just shifted over to the right and is now covering the weather forecast, rather than the text from the calendar entry expanding. What I’m trying to accomplish is to get the full calendar item text to show. Is there a way to do that?
                  Thanks,
                  Nathan
                  • cowboysdudeC
                    @deadherring said in Changing Module Display Width:
                    Thanks,
                    Nathan
                    Readjust it to a number that works to get it away from the weather… you have it at 450, try 400.
                    • brobergB
                      @deadherring add maxTitleLength : 50, in the calendar config, default is set to 25
                        deadherring
                        Thanks, that worked!
                        One thing I’m seeing is that my work calendar (Exchange) is not showing. I have A Google calendar that is updating but the Exchange is not. I can configure with a .ics file and .html and neither seems to work. If I copy and paste the Exchange url from config.js to a web browser it works fine, but it is not updating on the MagicMirror. I tried restarting the Pi but no go.
                        Any ideas on how I can troubleshoot? I haven’t updated the MM software in a few months, so I doubt I’m on the latest version.
                        Thanks,
                        Nathan
                          Srikanth 666 @cowboysdude
                          @cowboysdude
                          It’s not working, it’s showing error
                          what can I do
