    Trying to connect via SSH or VNC
    9 Posts 5 Posters 6.1k Views 5 Watching
    • F Offline
      funkdafied
      Maybe its a PI issue, I’m getting a 192.168.55.x address from wifi vs a 192.168.0.x address. Did I configure something incorrectly?
      • cowboysdudeC Offline
        https://forum.magicmirror.builders/topic/1330/magicmirror-fails-to-be-started-via-ssh-console/3
        • F Offline
          funkdafied
          Thank you for the link. However I am able to get the system running. I’m hoping to connect via SSH or VNC to configure remotely.
          I’ve followed the instructions in this article and still unable to connect.
          https://forum.magicmirror.builders/topic/1326/ipwhitelist-howto/2
            Projekt95
            May be a dumb question but have you activated the deamons for SSH and VNC on the Pi? :grinning:
            The IPs are probably because your WLAN Router/AP has a different IP-Range as the Interfaces for LAN configured.
            • romainR Offline
              romain
              You might have to activate the ssh through the sudo raspi-config panel. It should be under interfacing option. also you need to have ssh keys ssh-keygen It will ask you some stuff but you can let it empty
                Mykle1 Project Sponsor Module Developer @funkdafied
                @funkdafied said in Trying to connect via SSH or VNC:
                From the Pi desktop:
                • F Offline
                  funkdafied
                  Thank you everyone. I verified SSH is enabled and running by connecting to localhost. I can also ping my windows machine from the pi but not the other way around. Do I need to add something to my windows machine to access it via SSH? I know I’m missing something simple.
                  • F Offline
                    funkdafied
                    Thanks again I think I might have a good idea what is going on, when I hardwire to the pi I get the correct address and can connect to SSH without any issues (still trying to get VNC working) through mobaXterm. I’m using a LUMA system in the house and I wonder if one of the access points has that as a subnet. To be determined later. Now I can configure remotely thank you everyone for your assistance. Anyone have recommendations on modules to consider and suggestions on two-way mirror or film to use?
