    Trouble with config file, Error Create Config File
    12 Posts 5 Posters 13.0k Views 5 Watching
    • T
      twosix
      So when I boot up the mirror I get the unable to validate config error, and gives me a need to create config screen when booted. How do I fix?
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
              port: 8080,
              ipWhitelist: ["::ffff:192.168.1/24", "127.0.0.1", "::ffff:127.0.0.1", "::1"], // Set [] to allow all IP addresses.
              language: "en",
              timeFormat: "12",
              units: "imperial",
                              module: "alert",
                              module: "updatenotification",
                              position: "top_bar"
                              module: "clock",
                              position: "top_left"
                              header: "US Holidays",
                                                      symbol: "calendar-check-o ",
                                                      url: "webcal://p55-calendars.icloud.com/published/2/TDWYwJjbv2BpxxxxxxxxxxvpNrb4SlxsvZM-xxxxxxx\"
                              module: "compliments",
                              position: "lower_third"
                              module: "currentweather",
                                      locationID: "4460243",  //ID from http://www.openweathermap.org/help/city_list.txt
                                      appid: "1b3ccd1809XXXXXXXXb5830e444aa1"
                              module: "weatherforecast",
                              header: "Weather Forecast",
                              module: "newsfeed",
                              position: "bottom_bar",
                                      feeds: [
                                                      title: "New York Times",
                                      showSourceTitle: true,
                                      showPublishDate: true
      Mykle1M B 2 Replies Last reply Reply Quote 0
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @twosix
        @twosix said in Trouble with config file, Error Create Config File:
        How do I fix?
        Here! I did it for you. You had some crazy quote characters and a missing quote at the end of your calendar url. Just put your API back in for weather.
        var config = {
        port: 8080,
            language: "en",
            timeFormat: "12",
            units: "imperial",
                            module: "alert",
                            position: "top_bar"
                            module: "clock",
                                                    url: "webcal://p55-calendars.icloud.com/published/2/TDWYwJjbv2BpM3HLonfCqBBO$"
                                    appid: "YOUR API KEY"
                            module: "newsfeed",
                                    feeds: [
        • T
          twosix @Mykle1
          @Mykle1 Thank you, but that didn’t work…I looked back at my code and realized that the full calendar link got cut off, and it did have a quote on the end of it…so I am still not sure what is happening, thanks though!
          language: "en",
              timeFormat: "12",
              units: "imperial",
                              module: "alert",
                              position: "top_bar"
                              module: "clock",
                                                      url: "webcal://p55-calendars.icloud.com/published/2/TDWYwJjbv2BpM3HLxxxxxxxxxxxxxxxxxvZM-3TNpXNgZXsi192SI7M6pxxxxxxxxxxxxxxxxxxxxxxxXZCkcApre7Kg\"
                                      appid: "1b3ccd18090bb8048b4bb5830e444aa1"
                              module: "newsfeed",
                                      feeds: [
          • Mykle1M
            Uhh, I used that config and it fired up just fine
              bhepler Module Developer @twosix
              The “need to create config” error message usually means that you have not copied the example configuration file to the production file. You’ll want to copy the config.js.sample file to it’s final destination of config.js. You can use this command (assuming you haven’t changed the paths and you’re using a standard Raspberry Pi):
              cp /home/pi/MagicMirror/config/config.js.example /home/pi/MagicMirror/config/config.js
              • cowboysdudeC
                Yes you must do a cp to have a config.js to start with BUT before you make changes ALWAYS have a backup that works… ALWAYS.
                IF you’re not sure and you’re having config.js problems run it through here …
                http://esprima.org/demo/validate.html
                It will tell you where your errors are… I mean it’s nice of people to fix things but if you’re working on this at 2AM and nobody is here… you’re not getting your mirror to work until the next day ;)
                • T
                  twosix @Mykle1
                  @Mykle1 I did the same, I fired up the sample config and it worked fine, but then after I put my stuff in, it gave me the “WARNING? Could not validate config file. Please correct syntax errors. Starting with default configuration.”
                  And then when I loads up it says, “Please create config file.”
                  • T
                    twosix @cowboysdude
                    @cowboysdude Thank you, I ran that through my code and there appears to be no problems…I just can’t figure out what the problem is…I boot the mirror up normally by going:
                    cd Magic Mirror
                    npm start
                    and then I get the “WARNING? Could not validate config file. Please correct syntax errors. Starting with default configuration.”
                    and then when it loads the “Please create config file.”
                    • T
                      twosix @bhepler
                      @bhepler Thank you! I did this and it reset my config file, and that booted up fine, but when I put my information in, and started it:
                      cd MagicMirror
                      npm start
                      I got the "WARNING? Could not validate config file. Please correct syntax errors. Starting with default configuration.”
                      Then load it said “Please create config file.”
                      • Mykle1M
                        If the default config works then this should be telling you that you are not making config entries correctly. Start again from the default config, making sure it runs, then add one module at a time, making sure it still works after each entry, then backing up your config each time you successfully add a module. I don’t know what else to offer you. I fixed your first config and tested it.
                        • T
                          twosix @Mykle1
                          @Mykle1 Okay I did that, and figured out the problem is my calendar…is there anyway I can fix that?
                          • strawberry 3.141S
                            strawberry 3.141 Project Sponsor Module Developer @twosix
                            @twosix in all your examples you’re escaping the closing quote
                            you can see there that the next line is green which indicates that the string isn’t closed there probably. This happen because of the \ right in front of the quote character.
                            If the backslash doesn’t belong to your string remove it, if you need the backslash you have to escape the backslash by adding a second. like this:
                              url: "webcal://p55-calendars.icloud.com/published/2/TDWYwJjbv2BpM3HLxxxxxxxxxxxxxxxxxvZM-3TNpXNgZXsi192SI7M6pxxxxxxxxxxxxxxxxxxxxxxxXZCkcApre7Kg\\"
                            here you can see that the closing curly brace is no longer highlighted in green because the string is closed properly.
