    Problems with weather modules on new install
    10 Posts 4 Posters 5.1k Views 4 Watching
    • E Offline
      erik72
      I have tried several times installing and it all goes fine.
      No errors during updates or install.
      MM starts fine and most works, but weather and forecast is not there.
      I have followed the complete install guide.
      I’m running default config.js, no changes
      Any ideas would be nice, thanks
        Anhalter42 @erik72
        @erik72 you need an openweather.org API key, see documentation of for example currentweather-Module:
        appid
        The OpenWeatherMap API key, which can be obtained by creating an OpenWeatherMap account.
        This value is REQUIRED
        • E Offline
          erik72
          Thanks that worked, but every other time i change something i change something in config.js. I get the following error during startup :100:
          Whoops! There was an uncaught exception…
          { Error: listen EADDRINUSE :::8080
          at Object.exports._errnoException (util.js:1022:11)
          at exports._exceptionWithHostPort (util.js:1045:20)
          at Server._listen2 (net.js:1262:14)
          at listen (net.js:1298:10)
          at Server.listen (net.js:1376:9)
          at new Server (/home/pi/MagicMirror/js/server.js:27:9)
          at /home/pi/MagicMirror/js/app.js:219:18
          at loadNextModule (/home/pi/MagicMirror/js/app.js:168:5)
          at /home/pi/MagicMirror/js/app.js:163:6
          at Class.loaded (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:19:3)
          code: ‘EADDRINUSE’,
          errno: ‘EADDRINUSE’,
          syscall: ‘listen’,
          address: ‘::’,
          port: 8080 }
          first time it was the default config.js where i changed this line:
          ipWhitelist: [], // Set [] to allow all IP addresses.
          then i can copy config.js.sample to config,js and it works again
          i edit in nano
          Mykle1M B 2 Replies Last reply Reply Quote 0
            Mykle1 Project Sponsor Module Developer @erik72
            @erik72
            Paste your config.js file here. Remove your API keys first and precede the paste with three back ticks.
            • E Offline
              erik72 @Mykle1
              @Mykle1
              Got it working somehow :-) thanks for taking the time
                @erik72 said in Problems with weather modules on new install:
                Got it working somehow thanks for taking the time
                Even better. Enjoy your mirror.
                  bhepler Module Developer @erik72
                  EADDRINUSE
                  This usually means that you already have the mirror process running and attempted to start it again.
                  • E Offline
                    erik72 @bhepler
                    @bhepler
                    Perhaps I am starting/stopping in a wrong way.
                    Because often when I have made a config change it will fail, but work after a reboot.
                    I use npm start and Ctrl-Z in terminal to quit.
                      @erik72 If you’re working directly on the pi, you can use ctrl+q to stop the interface and return to the terminal. If you’re using SSH to remote into the pi, then ctrl+c should stop it right nicely.
                      You can always check to see if the mirror is running by typing ps ax | grep node. If you get anything in response more than 6957 pts/19 S+ 0:00 grep --color=auto node (where 6975 will be some random number) then the MM process is running and you’ll need to shut it down in order for it to process your changes.
                      • E Offline
                        erik72 @bhepler
                        @bhepler
                        Thanks, will give it a try.
                        This is a really friendly forum :-)
