Never used Linux, Could someone help me install MM onto my laptop?
I’m using an old laptop as my mirror, and will take it apart once I install the software. I’ve never used Linux, and I’d appreciate help on how to set it up. The tutorial’s manual install isn’t helping.
Thanks in advance
Alex -
First things first. What OS is the laptop running?
I’ve installed MM on 2 laptops. One is running Windows 7 and one is running uBuntu. Basically, you will need to install the newest version of node.js, npm and git for the platform you are using. Then a manual install of the MM software and dependencies.
I’ll try to guide you as you go along
Here is a very good guide on how to setup Linux :)
https://www.ubuntu.com/download/desktop/install-ubuntu-desktop
Hey guys, thanks for the info. I’m using Ubuntu, latest build. I think I’ve gotten the dependencies installed, but what way is best to make sure?
Thanks again
Alex -
Once you have Linux installed just follow the MM install instructions…
https://github.com/MichMich/MagicMirror
Manual Installation
Download and install the latest Node.js version.
Verison 6
curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
sudo apt-get install -y nodejsOR
Verison 8
curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
sudo apt-get install -y nodejsTHEN:
Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
Enter the repository: cd ~/MagicMirror
Install the app: npm install
Run the app: npm start
Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.IF you get any errors search this forum or Google your error to see how to fix…
Gotta go to work, Have a good day!!!
