    Never used Linux, Could someone help me install MM onto my laptop?
    5 Posts 3 Posters 5.9k Views 3 Watching
      alexx2208
      I’m using an old laptop as my mirror, and will take it apart once I install the software. I’ve never used Linux, and I’d appreciate help on how to set it up. The tutorial’s manual install isn’t helping.
      Thanks in advance
      Alex
        Mykle1 Project Sponsor Module Developer @alexx2208
        @alexx2208
        First things first. What OS is the laptop running?
        I’ve installed MM on 2 laptops. One is running Windows 7 and one is running uBuntu. Basically, you will need to install the newest version of node.js, npm and git for the platform you are using. Then a manual install of the MM software and dependencies.
        I’ll try to guide you as you go along
        • cowboysdudeC Offline
          Here is a very good guide on how to setup Linux :)
          https://www.ubuntu.com/download/desktop/install-ubuntu-desktop
            alexx2208
            Hey guys, thanks for the info. I’m using Ubuntu, latest build. I think I’ve gotten the dependencies installed, but what way is best to make sure?
            Thanks again
            Alex
              Once you have Linux installed just follow the MM install instructions…
              https://github.com/MichMich/MagicMirror
              Manual Installation
              Download and install the latest Node.js version.
              Verison 6
              curl -sL https://deb.nodesource.com/setup_6.x | sudo -E bash -
              sudo apt-get install -y nodejs
              OR
              Verison 8
              curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
              THEN:
              Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
              Enter the repository: cd ~/MagicMirror
              Install the app: npm install
              Run the app: npm start
              Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
              IF you get any errors search this forum or Google your error to see how to fix…
              Gotta go to work, Have a good day!!!
