    Working on the ole 32"...
    54 Posts 6 Posters 59.4k Views 6 Watching
    • cowboysdudeC
      OK back in business… got a better tv… all apart … touch screen working quite well :)
        cohron @cowboysdude
        @cowboysdude mind sharing hardware details on the monitor, mirror, and touchscreen? I finally got my MM plain monitor version but thinking I’d like a touchscreen mirror or just a touchscreen monitor type.
        FYI current plans are to build the first MMM-Pool module to link to my Pentair IntelliTouch via Autelis interface. Will keep everyone posted on progress.
        • cowboysdudeC
          cowboysdude Module Developer @cohron
          @cohron Currently :100:
          (Sorry for all the caps, I’m copying it off a website)
          32" Vizio TV [Not too expensive and looks really good]
          ASUS H110T/CSM LGA 1151 Intel H110 HDMI SATA 6Gb/s USB 3.0 Thin Mini-ITX Motherboards
          Intel Pentium G4400 Skylake Dual-Core 3.3 GHz LGA 1151 65W BX80662G4400
          SILVERSTONE NT07-115X Super Slim Profile CPU Cooler
          Laptop Power supply.
          USB Microphone
          32" IR Touch frame from AliExpress
          It’s going to also be running @strawberry-3-141 voice control module.
          I’m not using raspberry pi here because it just doesn’t have the power I need.
          I’m not using a mirror because it’s not a mirror… it’s a ‘command center’ for my house… that is the goal. I also ordered this - > https://hestiapi.com/
          In the future I’ll be adding things like lights, door locks, and zone controls via voice.
          It’s going to take a bit of time to fully realize my vision but there are a couple others doing or wanting to do the same thing here.
          That’s about it for now… :) Still in the planning stages.
            cohron @cowboysdude
            @cowboysdude said in Working on the ole 32"...:
            32" Vizio TV
            Very cool. I guess I’m building a command center myself, just didnt know what its called without the mirror. lol. I love my alexa integration but I had no way to see the status of all the devices (nests, sonos, soon pool) plus weather and calendar in one place.
            Just fyi, I really like Intel’s new compute stick, default runs windows 10 i think but may run linux for its small form factor. Cheap too.
            thanks for the info.
            • cowboysdudeC
              Yes a mirror that’s not a mirror :)
              I’m glad you are attempting it as well… when I get some pictures I’ll post them!
              • cowboysdudeC
                cowboysdude Module Developer @Advokaten
                @Advokaten said in Working on the ole 32"...:
                @cowboysdude exactly what did you do? lol
                Tried to pry in the wrong place…
                • cowboysdudeC
                  Let the testing on the 32 ‘command center’ mirror begin ;)
                  IR Touch frame works VERY well… responsive…was only supposed to be 1 point but it’s working with 5…
                  Going to try some ‘touch’ modules… keep you posted.
                  • cowboysdudeC
                    Some things I’ve been working on ;)
                    I try to do modules that do NOT require API keys… The majority of modules I’ve made do NOT require them… MUCH easier…less signing up to do… less headaches…
                    • Mykle1M
                      That’s downright classy. The diversity of your modules is outstanding. I especially like the weather at the bottom and the way it is formatted.
                      Obviously, you’re a freakin guru!
                      • cowboysdudeC
                        • cowboysdudeC
                          Progress…waiting on Thermostat and other sensors to arrive :)
                          • Mykle1M
                            @cowboysdude
                            I’m running out of compliments bro. :-)
                            • 3 / 3
