    Magic Mirror on the Raspberry Pi 1, agonizingly difficult
    Scheduled Pinned Locked Moved Unsolved Tutorials
    magic mirrorraspberry piraspberry pi 1problems running mmserveronly
    33 Posts 8 Posters 29.4k Views 7 Watching
      McSorley
      It would be http://localhost:8080
        MMRPi1
        It says that the site can’t be reached and that localhost refused to connect
          A Former User
          @MMRPi1 What kind of messages are shown when you run node serveronly in the shell?
          M 1 Reply Last reply
            MMRPi1 @Guest
            @Sean
              A Former User
              You need express.js
              I guess your auto-installation process didn’t work anyhow. You can try manual installation. (And I recommend that.)
              See this.
                MMRPi1 @Guest
                @Sean I’ve tried following the instructions on that page but it hasn’t worked.
                How do I install express.js?
                ? 1 Reply Last reply
                  A Former User @MMRPi1
                  @MMRPi1 hmmm…
                  1. Go to your MagicMirror directory.
                  2. Is there package.json file in your MagicMirror directory? (..../MagicMirror/package.json)
                  3. If there is, open package.json you can see like this.
                    "dependencies": {
                      "body-parser": "^1.17.1",
                      "colors": "^1.1.2",
                      "electron": "^1.4.7",
                      "express": "^4.14.0",
                      "express-ipfilter": "latest",
                      "feedme": "latest",
                  1. Then, you can run npm install in /MagicMirror directory.
                  2. See how it goes.
                    MMRPi1
                    I’ve got a progress bar that’s progressing slowly, hopefully it will work, though it ma take a while.
                    Updates to follow…
                      @MMRPi1 good luck to you. :D
                        MMRPi1
                        Alright, it says Magic Mirror installation was successful, but I’m not sure what to do next…
                          MMRPi1
                          It worked!!
                          Thank you to everyone :-D
                          Now all that’s left is screensaver, autostart and all that…
                          Thanks again!
                          • cowboysdudeC
                            cowboysdude Module Developer @MMRPi1
                            @MMRPi1 Thank you for your patience! :) Glad you got it running now some advice…
                            IF you have a working config before you make ANY changes to it copy it to config.bak that way you’ll always have a GOOD working config file…
                            Good Luck!
                            Mykle1M M 2 Replies Last reply
                            • Mykle1M
                              @cowboysdude said in Magic Mirror on the Raspberry Pi 1, agonizingly difficult:
                              This is excellent advice!
                                MMRPi1 @cowboysdude
                                @cowboysdude Thanks.
                                This is the situation:
                                The default config file is working (I have it backed up) though when I run it in server only the clock and weather work fine, but all the other modules say “Loading…”.
                                I did try to customise it, but got the “No config file”, so either I have syntax errors or the sources aren’t right…
                                Talking of, does anyone know of a list of compatible news feeds and the like?
                                Thanks again
                                  @MMRPi1
                                  Can you show your config.js here? It makes easier.
                                  If you got “no config file” however you have a confidence for config.js existence, you might make some syntax error in your config.js.
                                  you can find newsfeed rss in most news sites.
                                  If some site has links of “RSS”(or small orange squared antenna icon), you can use that url to your newsfeed.
                                  By example, If you want to get news from “The Washington Post”, google “washington post rss”. Then the result pages direct you to WP rss page. get a link what you want, apply that to your news-feed module config.
                                  Most of the RSS could be compatible with that module. Even RSS of personal blogs also.
                                  Some browsers(Firefox, IE7…) support finding RSS on current page. You can see RSS mark in addressbar if current page has valid RSS link.
                                  You can check the reference. (I doubt there are some missing links.)
                                  https://www.repeatserver.com/RSSFeedList.aspx
                                  http://www.uen.org/feeds/lists.shtml
                                    MMRPi1
                                    Good news!
                                    The config file is (mostly) working (it needed a reboot) and I’ll configure it until I’m satisfied at which point I need to figure out how to keep it fullscreen, disable screen timeout and do the autostart and all that…
                                    In the meantime, thanks to everyone for their help :-D
                                    • cowboysdudeC
                                      @MMRPi1 said in Magic Mirror on the Raspberry Pi 1, agonizingly difficult:
                                      Good news!
                                      You’re very welcome. :) Enjoy!
                                        MMRPi1
                                        Now the software is working I have a few more questions:
                                        (Btw I’m running MM in serveronly mode in Chromium.)
                                        1. How do I make MM auto run when the Pi turns on, disable screensaver and make it fullscreen?
                                        2. Should I be concerned that the RPi gets quite hot in operation, especially as it will be in a frame and in constant operation.
                                        3. Is it advisable to turn the raspberry pi off (and turn off the magic mirror) by switching it off at the mains, and if not how would I turn it off and on?
                                        ? Mykle1M 2 Replies Last reply
                                          MMRPi1
                                          Also, how do you rotate the screen??
                                          Mykle1M 1 Reply Last reply
                                            @MMRPi1
                                            For autostart, read this
                                            Don’t worry about heat unless overclocking. However you can add small pan and ventilatoin holes on your frame.
                                            You can use cron for scheduly shutdown or reboot. But you cannot turn on RPI automatically. You need additional hardware for that. You can consider timer switch or outlet.
                                            For display rotating, edit /boot/config.txt
                                            Add
                                            display_rotate=1
