    22'' Display + 40cmx50cm IKEA Frame + PIR Sensor
    29 Posts 13 Posters 43.9k Views 15 Watching
    • KimzerK Offline
      Kimzer
      Looks really good. Thinking about using the same ikea frame.
      Did you use some film on the glass or did you end up buying a one way mirror?
        ryck Module Developer
        I used a film and the glass included with the frame, as I didn’t want to go crazy for my first magic mirror, but as soon as I get another display ( a good one) I will order a proper two way mirror and make another one using the same frame (super easy to do and quite cheap)
          A Former User
          You are the genius!! I considered IKEA RIBBA, but I gave up the idea because the depth was not enough. How can you find “Back-to-Back” solution! I should have read this article 1 weeks before.
            ryck Module Developer @Guest
            @Sean Well, to be honest, my wife deserves all the credit: I was desperate after 2 weeks of trying to do my own frame, including butchering 3 RiBBAs (just to get the glass) and my wife just said: hey, you already have two unused frames, why you just don’t glue them back to back? MIND BLOWN
              AZ_Geek
              @ryck Would please you post a hardware list with prices? I like your setup and it looks like a simple cost effective design for my first project.
                ryck Module Developer @AZ_Geek
                @AZ_Geek I can try :)
                Required
                • Old 22’’ display (£10)
                • 2 x IKEA RIBBA 40x50
                • One way reflective film
                • Micro SDHC
                • Raspberry Pi 3 B
                • HDMI to VGA adaptor
                Optional
                • PIR Sensor
                • Jumper wires
                • DHT22
                • Mini buttons
                You will also need some glue to join the two frames together, an extension lead to plugin everything inside the frame, a drill to hang the frame and make a hole for the extension lead cable… but hopefully you’ll have all this things already.
                Good luck with your new MagicMirror!
                • T Offline
                  TGBB
                  Isn’t a 40/50 Ribba frame at Ikea…?!? Thinking of using this or two back to back. Also can you quote the one way reflective film you used as the link was just a link to Ebay.
                    MyMirror
                    Hey ryck,
                    is it possible to show us some pictures from the backside how do you placed the PIR ?
                    How do you fix the PIR and, if possible, the connection from the PIR to the raspi …
                    And what hight did your RIBBA have?
                    Thanks!
                      ryck Module Developer @MyMirror
                      @MyMirror Sure, I’ll try tonight, but I can already tell you:
                      • The PIR is attached to the bottom of the frame with some bluetack
                      • The PIR sensor is using this “module” so just follow the instruction (ie, here)
                      • My frame was 40x50, but you have more options, just choose the one that works better for you (and fits your screen, of course)
                      Good luck!
                        ryck Module Developer @TGBB
                        @TGBB Yeah, just two 40x50 RIBBA frames glued back to back…
                        Any reflective film will work. Seems like the link I posted is not valid anymore, but you could use something like this…
