    22'' Display + 40cmx50cm IKEA Frame + PIR Sensor
    29 Posts 13 Posters 48.0k Views 15 Watching
    • T
      TGBB
      Isn’t a 40/50 Ribba frame at Ikea…?!? Thinking of using this or two back to back. Also can you quote the one way reflective film you used as the link was just a link to Ebay.
      R 1 Reply Last reply
        MyMirror
        Hey ryck,
        is it possible to show us some pictures from the backside how do you placed the PIR ?
        How do you fix the PIR and, if possible, the connection from the PIR to the raspi …
        And what hight did your RIBBA have?
        Thanks!
          ryck Module Developer @MyMirror
          @MyMirror Sure, I’ll try tonight, but I can already tell you:
          • The PIR is attached to the bottom of the frame with some bluetack
          • The PIR sensor is using this “module” so just follow the instruction (ie, here)
          • My frame was 40x50, but you have more options, just choose the one that works better for you (and fits your screen, of course)
          Good luck!
            ryck Module Developer @TGBB
            @TGBB Yeah, just two 40x50 RIBBA frames glued back to back…
            Any reflective film will work. Seems like the link I posted is not valid anymore, but you could use something like this…
            M 1 Reply Last reply
              MyMirror @ryck
              Hey ryck, thanks for the details.
              Did your monitor shows information like “no HMDI found” or “lost signal” or anything like this, when the PIR turns off the screen?
              If not … what have you done to suppress the text/infos?
              Or is your monitor smart enough to do that for you?
              Greets
              MyMirror
                @MyMirror I don’t get any text on the display when it goes off, maybe the display is smart enough? Are you using the same software to turn it off?
                  MyMirror @ryck
                  Hi @ryck,
                  i think it is python …
                  I just get “Python 2 (IDLE)” on my menue.
                  I’ll try to force an update with
                  sudo apt-get update
                  sudo apt-get upgrade
                  sudo apt-get install --reinstall python3
                  but, after reboot, nothing happens. I’ve got just python2 on my menue.
                  (After searching in the main menue Editor …)
                  OK - found python3 but without IDLE) - but this should not be the problem, or?
                  But if it is “easy” to install the IDLE - can you give me a hint?
                  I use pin 14 - as in the pir.py written - nothing happens … :-(
                  I think, it is the missing line 7 in the pir.py.
                  You wrote:
                  You have to change line 7 to the location of the pir.py file like this:
                  ExecStart=/usr/bin/python /path/to/your/pir.py
                  But in my pir.py i didn’t find a line like this …
                  Can you help me?
                  MyMirror
                    @MyMirror in the pir.py file you need to change only one thing, the GPIO data pin to which the PIR sensor is connected (you can double check yours here: https://pinout.xyz/). The line is this one: https://github.com/deg0nz/MagicMirror-Display-Controller/blob/master/pir.py#L8
                    That should be all.
                    The line 7 stuff is for the service (ie, run the script automatically every time the Pi reboots) and is in a different file: https://github.com/deg0nz/MagicMirror-Display-Controller/blob/master/pir_sensor.service#L7
                    C 1 Reply Last reply
                      MyMirror
                      Merry xmas :-),
                      thanks … your script works - my monitor not really :-(
                      If your script power off HDMI i’ll get a “HDMI”-Logo and “no Signal” … bad :-(
                      It seems that i have to buy a different screen.
                      Which one do you use? Is it available as 32’’ ?
                      Greets
                      MyMirror
                        MyMirror
                        You can see it here :-(
                        –> https://1drv.ms/v/s!ApE0YZ4Ndle9jzjzH7u3vSCmXb7G
                          doubleT Module Developer
                          Nice mirror. Have you considered leading the cable to the right and down along the corner of the wall? Might look even cleaner. And if it’s a selfmade cable, I’d consider some white cable sleeving.
                            cornusandu @ryck
                            @ryck hello. Please, would you consider making a video on installing software steps for morons like me? I manage to install the module but after that I was lost completely. Following the github Magic Mirror pir control hdmi. If you would be kind enough to make that video please consider every step as I am a complete noob and a moron considering raspbian. I was lucky that there are a great number of videos on how to install Magic Mirror otherwise I would never been able to get it done. Thank you very much.
                            C R 2 Replies Last reply
                              cornusandu @cornusandu
                              @cornusandu said in 22’’ Display + 40cmx50cm IKEA Frame + PIR Sensor:
                              PS. I do not understand how to install and get it working Magic Mirror Display Control for the PIR
                                ryck Module Developer @cornusandu
                                @cornusandu I don’t think a video will help you, you just need to follow the instructions here: https://github.com/deg0nz/MagicMirror-Display-Controller
                                Make sure you you set the path and the the pin variable to the correct values and that’s it.
                                • floF
                                  flo
                                  @ryck Do you know the model you have been using for this (great) mirror? Probably there is something on ebay…
                                    ryck Module Developer @flo
                                    @flo You mean the monitor model? I don’t know for sure, I think is a viewsonic, but I’ll try to get the model later…
                                    But to be honest, anything will do the part, just get anything cheap and start from there :)
                                    • floF
                                      flo
                                      @ryck I just wanted to know the model, because the PIR seems to work well with this model (no input warning when suspending).
                                        poopyurinal
                                        I know this is an old thread, but do you recall what type of glue you used to glue the two frames together? Wood? Super? I can’t quite tell what the frame coating is made of.
                                          ryck Module Developer @poopyurinal
                                          @poopyurinal Just " No more nails" from unibond, but any wood glue will work. I don’t recommend superglue though…
                                          • ejay-ibmE
                                            ejay-ibm Project Sponsor Module Developer
                                            Very nice idea to glue 2 frame ! I haven’t thought about doing that when I created my mirror . That would have save me lot of time !
                                            I’ll make my same usual request :) : Can we see the back and inside of your mirror ?
                                            Thank you
                                            Ejay
