    MagicMirror² v2.1.2: Wrong calendar timeFormat after update
    7 Posts 4 Posters 3.9k Views 4 Watching
      djsunrise19
      I’ve updated my mirror to MagicMirror² v2.1.2. I’m working with the 24 timeFormat, but my events seems to be in 12. The following event is at 16:30, not 04:30. I created some test-events. It’s the same problem with them. Before I updated, everything was fine.
      Anyone else with this problem?
      Regards
      Maurice
        djsunrise19
        Nobody else?
          Jopyth Moderator @djsunrise19
          @djsunrise19 You can hotfix it yourself if you want: Github Issue
            djsunrise19
            Ah, I see. Thank you! There is a commit, too. I’ll wait for the update!
            • FallandeGubbeF Offline
              FallandeGubbe
              I have the same issue.
              A noob question: how do I “hotfix” if I don’t want to wait for update?
              • randomnoiseR Offline
                randomnoise
                Edit your calendar.js
                Find the bit that says-
                longDateFormat
                Change LT: “hh:mm”
                To
                LT: “HH:mm”
                FallandeGubbeF 1 Reply Last reply Reply Quote 1
                  FallandeGubbe @randomnoise
                  @randomnoise Great! Thank you, now it works as intended again :)
