    stronger Raspberry Pi 3 Alternatives
    50 Posts 11 Posters 65.9k Views 10 Watching
    • SvenSommerS
      SvenSommer
      Several modules like the ones for face recognition, speech recognition or even streaming from webcams bring the Raspberry Pi 3 to it’s performance limits by max out it’s memory and cpu. I found some older topics where several alternatives where named. Unfortunately those post were abandoned like half a year ago and really hard to read, due to the overlapping conversations.
      I really want to find a powerful alternative to the Pi3. Perhaps the experienced builders can briefly share what they have done for experience with your alternatives. I think the following criteria are interesting.
      Everybody else please don’t forget to up vote the contributions of those who share.
      Model: Raspberry Pi 3 Model B
      Price
      • Board - 35 $
      • Power Supply (mini USB) - 5 $
      in Total: about 40 $
      Dimensions
      85.60mm x 56mm x 21mm
      Hardware Specifications
      • CPU: Quad Core 1.2GHz Broadcom BCM2837 64bit CPU
      • Memory: 1GB RAM
      • WLAN: BCM43438 wireless LAN and Bluetooth Low Energy (BLE) on board
      • GPIO Pins:: 40-pin extended
      • USB: 4x USB 2.0 ports
      • Video & Stereo output: 4 Pole stereo output and composite video port
      • Full size HDMI
      • CSI camera port for connecting a Raspberry Pi camera
      • DSI display port for connecting a Raspberry Pi touchscreen display
      • Micro SD port for loading your operating system and storing data
      • Upgraded switched Micro USB power source up to 2.5A
      Software:
      OS: Raspian
      Is able to run:
      • NodeJS - yes
      Installation of MM:
      • Is the standard installation script executable? - yes
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)
      Remarks:
      • Strong spread, big supportive community.
      Model: Intel Thin Mini-ITX Motherboard
      like ASUS H110T/CSM LGA 1151 Intel H110 HDMI SATA 6Gb/s USB 3.0 Thin Mini-ITX Motherboards
      Price
      • Board: 80 $
      • Ram: 8 GB - 70 $
      • Wifi Card: 27 $
      • CPU: 56 $
      • Cooler: 20$
      • SSD: 128GB - 30 $
      • accepts 12 to 19 Volts Power Supply as for notebooks - 15 $
      in Total: about 300 $ (depending on components)
      Dimensions
      1702mm x 1702 x 25mm
      • Supported CPU (CPU not included)
        • Socket Type: LGA 1151
        • CPU Type: **Core i7 / i5 / i3 / Pentium / Celeron (LGA1151)
        • Supported CPU Technologies: * Turbo Boost Technology 2.0
      • Memory (not included)
        • Number of Memory Slots: 2×260pin
        • Memory Standard: DDR4 2133
        • Maximum Memory Supported: 32GB
        • Channel Supported: Dual Channel
      • Onboard Video:
        • Integrated Graphics Processor
        • Multi-VGA output support: DP/HDMI/LVDS ports
        • Supports HDMI with max. resolution of 4096 x 2160 @ 24Hz / 2560 x 1600 @ 60Hz
        • Supports LVDS with max. resolution of 1920 x 1200 @ 60Hz
        • Supports DisplayPort with max. resolution of 4096 x 2304 @ 60 Hz
        • Maximum shared memory of 1024MB
      • WLAN: only by using expansion Slot for 1 x M.2 Socket 1 with E key, type 2230 for WIFI device
      • LAN: Dual 10/100/1000Mbps with Realtek 8111H
      • GPIO Pins: no
      • Rear Panel Ports
        • 1 x HDMI
        • 2 x RJ45
        • 1 x DisplayPort
        • 4 x USB 3.0
        • 2 Audio Ports
      • Onboard USB:
        • 2 x USB 2.0 2-port connectors support additional 4 USB 2.0 ports
        • 1 x USB 2.0 1-port connectors support additional 1 USB 2.0 port
      • Full size HDMI
      Software:
      Operating System Support:
      • Unbuntu
      • Windows 10*
      • Windows 8.1*
      • Windows 7
      • 64-bit supported only
      Is able to run:
      • NodeJS - yes
      Installation of MM:
      Remarks:
      • Powerfull Board with several upgrading capabilities which comes with a bigger pice tag
      • Quotes:
        • “So things like @strawberry-3-141 voice module is REALLY fast and responsive. I’m also using an IR touch frame that responds quite well with no additional drivers needed.”
      Looking for some building inspiration?
      Check out my large, thin and metal framed mirror on robstechlog.com.
      Modules released:
      MMM-GoogleAnalytics
      MMM-GrafanaChart
      MMM-GrafanaGauges
      Reply Quote 6
      • cowboysdudeC
        I am using an RPi3 for my bathroom but the 32" inch mirror I"m using a mini itx board with intel chip 8 gig of ram and 120G SSD.
        It has the wireless mini card and the video is amazing. I realize the mirror was built based on the RPi but using a real board gives it that much more power.
        Love the RPi but it just wasn’t giving me what I wanted and wanted to be able to do with this project so I opted for more power… :)
        SvenSommerS J 2 Replies Last reply
        Reply Quote 4
        • SvenSommerS
          SvenSommer @cowboysdude
          @cowboysdude
          Thanks for your answer.
          Could you please share a link which mini itx board board you’re exactly using?
          Modules released:
          MMM-GoogleAnalytics
          MMM-GrafanaChart
          MMM-GrafanaGauges
          • cowboysdudeC
            cowboysdude Module Developer @SvenSommer
            @SvenSommer
            It’s the ASUS H110T/CSM LGA 1151 Intel H110 HDMI SATA 6Gb/s USB 3.0 Thin Mini-ITX Motherboards - Intel
            Link is here but it’s no longer available:
            https://www.newegg.com/Product/Product.aspx?Item=N82E16813132833
            I’m pretty sure there are others with similar specs out there… I’m using a notebook power supply for this.
            Ram: https://www.amazon.com/gp/product/B015HQ9TGW/ref=oh_aui_detailpage_o03_s00?ie=UTF8&psc=1
            WiFi card: https://www.amazon.com/gp/product/B00GUNZUG0/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
            CPU: https://www.newegg.com/Product/Product.aspx?Item=N82E16819117625
            CPU Cooler: https://www.newegg.com/Product/Product.aspx?Item=N82E16835220067
            And a SanDisk 120GB SSD
            D SvenSommerS 2 Replies Last reply
            Reply Quote 3
              Damian @cowboysdude
              @cowboysdude
              Hello can you show the set up of the mini itx in situ at all? And what case you used if any. Thank you
              • SvenSommerS
                @cowboysdude
                I just updated the summary post, could you please check, if there is everything correct?!
                Modules released:
                MMM-GoogleAnalytics
                MMM-GrafanaChart
                MMM-GrafanaGauges
                Reply Quote 2
                • cowboysdudeC
                  cowboysdude Module Developer @Damian
                  @Damian said in stronger Raspberry Pi 3 Alternatives:
                  @cowboysdude
                  I will take a pic this weekend but as of right now it’s ‘on the bench’ and I don’t have a case as of yet. More than likely will be designed to attached to the wall of the cabinet and not in a case…
                  D 1 Reply Last reply
                  • cowboysdudeC
                    @SvenSommer said in stronger Raspberry Pi 3 Alternatives:
                    @cowboysdude
                        Windows 10*
                        Windows 8.1*
                        Windows 7
                    Under that I would also put Linux… I’m running Unbuntu on the machine currently which makes it much easier to run MM :)
                    Reply Quote 3
                    • cowboysdudeC
                      I would, and will at some point, use one of these in place of the SSD… to further compact things…
                      https://www.newegg.com/Product/Product.aspx?Item=N82E16820228162&ignorebbr=1![0_1500685862979_20-228-162-03.jpg](/assets/uploads/files/1500685862470-20-228-162-03.jpg)
                        Damian @cowboysdude
                        @cowboysdude said in stronger Raspberry Pi 3 Alternatives:
                        Thank you. Yes i looked at cases but none were slim/small enough. Look forward to your snaps to see how yours look set up. What power source did you use?
                        • cowboysdudeC
                          @Damian I am using a laptop power supply :)
                            Damian @cowboysdude
                            thank you. i could not see a link to it in the first post so just wondered what one you chose. looking forward to your pictures of the setup of your itx when you get time
                            • SnilleS
                              Snille Module Developer
                              I just found this one: https://www.kickstarter.com/projects/librecomputer/libre-computer-board-next-gen-4k-sbc-dev-board-for/description
                              It may be an alternative. :)
                              SvenSommerS 1 Reply Last reply
                              Reply Quote 3
                              • SvenSommerS
                                SvenSommer @Snille
                                @Snille Yes, very interesting. I liked the idea of comparing the boards with Geekbench. Maybe this is a measurable unit to compare.
                                @cowboysdude Are you willing to run such a Geekbench on your system?
                                Somebody backed this and is going to get a one?
                                Modules released:
                                MMM-GoogleAnalytics
                                MMM-GrafanaChart
                                MMM-GrafanaGauges
                                SnilleS 1 Reply Last reply
                                • cowboysdudeC
                                  I think that’s awesome. IF it has more power, and it seems these boards are getting more powerful all the time, that’s a good thing!
                                  • SnilleS
                                    Snille Module Developer @SvenSommer
                                    @SvenSommer Yes, I’m backing it. :) I’m going (if it works) to replace my Pi3 with it. :)
                                    Reply Quote 2
                                    • cowboysdudeC
                                      cowboysdude Module Developer @Snille
                                      @Snille I would but right now I have so much going on that backing anything else would be counter productive.
                                      I’m backing a Thermostat right now… and that’s keeping my butt busy :)
                                        Damian @cowboysdude
                                        @cowboysdude
                                        hello. I cannot remember if you did a post here about your steps installing ubuntu? can you direct me to it please, if you did indeed do one?
                                        I’m about to dual boot a win7 mini itx with ubuntu over the weekend, and then install MM, for the extra power it will give, and also wondered if JRE is installed with the ubuntu installer, or whether I need to do that separately? if this is needed of course?
                                        Also any hints/tips/pitfalls you can offer, about the install, will be greatly appreciated. thank you.
                                        • cowboysdudeC
                                          JRE
                                          I didn’t do dual boot only because well Windows is blah LOL
                                          I straight just installed Unbuntu then followed the instructions for manual Magic Mirror install and I’ve had no problems at all! :)
                                          Here’s a guide for Unbuntu:
                                          https://tutorials.ubuntu.com/tutorial/tutorial-install-ubuntu-desktop#0
                                          I installed from a USB Stick :)
                                          Reply Quote 2
                                            Damian @cowboysdude
                                            JRE
                                            Yes, was unsure if I needed to install the Java Runtime Environment as a seperate, or whether ubuntu installs that itself? Or indeed if it is needed at all?
                                            Agree, but i want to keep it on the other half of the 500gb drive for a future project.
                                            Good to know there is no issues/problems to look out for. This will be first time installing and using ubuntu, so was unsure if it is as straight forward as raspbian to set up and run, and get MM on top.
                                            I will now look forward to use MM without the usual RP3 constraints.
                                            Than you very much for this, I will have an enjoyable weekend setting this all up.
