    stronger Raspberry Pi 3 Alternatives
    50 Posts 11 Posters 65.9k Views 10 Watching
    • cowboysdudeC
      cowboysdude Module Developer @Damian
      @Damian said in stronger Raspberry Pi 3 Alternatives:
      @cowboysdude
      Hello can you show the set up of the mini itx in situ at all? And what case you used if any. Thank you
      I will take a pic this weekend but as of right now it’s ‘on the bench’ and I don’t have a case as of yet. More than likely will be designed to attached to the wall of the cabinet and not in a case…
      D 1 Reply Last reply
      • cowboysdudeC
        cowboysdude Module Developer @SvenSommer
        @SvenSommer said in stronger Raspberry Pi 3 Alternatives:
        @cowboysdude
        I just updated the summary post, could you please check, if there is everything correct?!
           Operating System Support:
            Windows 10*
            Windows 8.1*
            Windows 7
            64-bit supported only
        Under that I would also put Linux… I’m running Unbuntu on the machine currently which makes it much easier to run MM :)
        Reply Quote 3
        • cowboysdudeC
          I would, and will at some point, use one of these in place of the SSD… to further compact things…
          https://www.newegg.com/Product/Product.aspx?Item=N82E16820228162&ignorebbr=1![0_1500685862979_20-228-162-03.jpg](/assets/uploads/files/1500685862470-20-228-162-03.jpg)
            Damian @cowboysdude
            @cowboysdude said in stronger Raspberry Pi 3 Alternatives:
            Thank you. Yes i looked at cases but none were slim/small enough. Look forward to your snaps to see how yours look set up. What power source did you use?
            • cowboysdudeC
              @Damian I am using a laptop power supply :)
                Damian @cowboysdude
                thank you. i could not see a link to it in the first post so just wondered what one you chose. looking forward to your pictures of the setup of your itx when you get time
                • SnilleS
                  Snille Module Developer
                  I just found this one: https://www.kickstarter.com/projects/librecomputer/libre-computer-board-next-gen-4k-sbc-dev-board-for/description
                  It may be an alternative. :)
                  SvenSommerS 1 Reply Last reply
                  Reply Quote 3
                  • SvenSommerS
                    SvenSommer @Snille
                    @Snille Yes, very interesting. I liked the idea of comparing the boards with Geekbench. Maybe this is a measurable unit to compare.
                    @cowboysdude Are you willing to run such a Geekbench on your system?
                    Somebody backed this and is going to get a one?
                    Looking for some building inspiration?
                    Check out my large, thin and metal framed mirror on robstechlog.com.
                    Modules released:
                    MMM-GoogleAnalytics
                    MMM-GrafanaChart
                    MMM-GrafanaGauges
                    SnilleS 1 Reply Last reply
                    • cowboysdudeC
                      I think that’s awesome. IF it has more power, and it seems these boards are getting more powerful all the time, that’s a good thing!
                      • SnilleS
                        Snille Module Developer @SvenSommer
                        @SvenSommer Yes, I’m backing it. :) I’m going (if it works) to replace my Pi3 with it. :)
                        Reply Quote 2
                        • cowboysdudeC
                          cowboysdude Module Developer @Snille
                          @Snille I would but right now I have so much going on that backing anything else would be counter productive.
                          I’m backing a Thermostat right now… and that’s keeping my butt busy :)
                            Damian @cowboysdude
                            @cowboysdude
                            hello. I cannot remember if you did a post here about your steps installing ubuntu? can you direct me to it please, if you did indeed do one?
                            I’m about to dual boot a win7 mini itx with ubuntu over the weekend, and then install MM, for the extra power it will give, and also wondered if JRE is installed with the ubuntu installer, or whether I need to do that separately? if this is needed of course?
                            Also any hints/tips/pitfalls you can offer, about the install, will be greatly appreciated. thank you.
                            • cowboysdudeC
                              JRE
                              I didn’t do dual boot only because well Windows is blah LOL
                              I straight just installed Unbuntu then followed the instructions for manual Magic Mirror install and I’ve had no problems at all! :)
                              Here’s a guide for Unbuntu:
                              https://tutorials.ubuntu.com/tutorial/tutorial-install-ubuntu-desktop#0
                              I installed from a USB Stick :)
                              Reply Quote 2
                                Damian @cowboysdude
                                JRE
                                Yes, was unsure if I needed to install the Java Runtime Environment as a seperate, or whether ubuntu installs that itself? Or indeed if it is needed at all?
                                Agree, but i want to keep it on the other half of the 500gb drive for a future project.
                                Good to know there is no issues/problems to look out for. This will be first time installing and using ubuntu, so was unsure if it is as straight forward as raspbian to set up and run, and get MM on top.
                                I will now look forward to use MM without the usual RP3 constraints.
                                Than you very much for this, I will have an enjoyable weekend setting this all up.
                                • strawberry 3.141S
                                  strawberry 3.141 Project Sponsor Module Developer @Damian
                                  @Damian does it make sense then to just setup ubuntu for magicmirror? You got windows already and magicmirror works also on windows
                                  Reply Quote 2
                                    Damian @strawberry 3.141
                                    @strawberry-3.141 said in stronger Raspberry Pi 3 Alternatives:
                                    @Damian You got windows already and magicmirror works also on windows
                                    I never thought about that. :-(
                                    I just went back over posts here and seen one from @Mykle1 about setting up on his windows PC
                                    https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7
                                    I just thought that MM would run better on a linux distro system partition, more than on a full Win system? If there is a difference that is?
                                    Thanks for that, as this will save some time, and thanks to @Mykle1 for his guide.
                                    • cowboysdudeC
                                      @Damian I don’t think it really matters. I just prefer Linux … Just easier for me.
                                        Damian @cowboysdude
                                        Thank you. Really looking forward to seeing the difference in power with MM.
                                        fyi… I was going to build an itx like you mentioned in here, but seen a mint condition Lenovo Q180 going for a song on ebay, so bought it, and it is perfect for my next MM. 2.13 GHz 4GB ram 500GB HDD.
                                        • cowboysdudeC
                                          Makes a HUGE difference :) You’ll love it.
                                          • emloweE
                                            emlowe Module Developer
                                            Here is another option:
                                            ASRock N3150DC-ITX Mini-ITX Motherboard - if you can find one.
                                            SoC – Intel Celeron N3150 quad core processor @ up to 2.08 GHz with Intel HD Graphics Gen8 @ up to 640 MHz – 6W TDP
                                            There are some other Celeron SoC boards that take 19v DC power. The Asus Q1900DC-ITX uses the J1900.
                                            Look for “Thin Mini-ITX” normally that means the DC in.
                                            -Earle
                                            Reply Quote 2
