    stronger Raspberry Pi 3 Alternatives
    50 Posts 11 Posters 63.6k Views 10 Watching
    • SnilleS Offline
      Snille Module Developer @SvenSommer
      @SvenSommer Yes, I’m backing it. :) I’m going (if it works) to replace my Pi3 with it. :)
      • cowboysdudeC Offline
        cowboysdude Module Developer @Snille
        @Snille I would but right now I have so much going on that backing anything else would be counter productive.
        I’m backing a Thermostat right now… and that’s keeping my butt busy :)
          Damian @cowboysdude
          @cowboysdude
          hello. I cannot remember if you did a post here about your steps installing ubuntu? can you direct me to it please, if you did indeed do one?
          I’m about to dual boot a win7 mini itx with ubuntu over the weekend, and then install MM, for the extra power it will give, and also wondered if JRE is installed with the ubuntu installer, or whether I need to do that separately? if this is needed of course?
          Also any hints/tips/pitfalls you can offer, about the install, will be greatly appreciated. thank you.
            cowboysdude Module Developer @Damian
            @Damian said in stronger Raspberry Pi 3 Alternatives:
            JRE
            I didn’t do dual boot only because well Windows is blah LOL
            I straight just installed Unbuntu then followed the instructions for manual Magic Mirror install and I’ve had no problems at all! :)
            Here’s a guide for Unbuntu:
            https://tutorials.ubuntu.com/tutorial/tutorial-install-ubuntu-desktop#0
            I installed from a USB Stick :)
            D 1 Reply Last reply Reply Quote 2
              Damian @cowboysdude
              @cowboysdude said in stronger Raspberry Pi 3 Alternatives:
              JRE
              Yes, was unsure if I needed to install the Java Runtime Environment as a seperate, or whether ubuntu installs that itself? Or indeed if it is needed at all?
              Agree, but i want to keep it on the other half of the 500gb drive for a future project.
              Good to know there is no issues/problems to look out for. This will be first time installing and using ubuntu, so was unsure if it is as straight forward as raspbian to set up and run, and get MM on top.
              I will now look forward to use MM without the usual RP3 constraints.
              Than you very much for this, I will have an enjoyable weekend setting this all up.
              • strawberry 3.141S Offline
                strawberry 3.141 Project Sponsor Module Developer @Damian
                @Damian does it make sense then to just setup ubuntu for magicmirror? You got windows already and magicmirror works also on windows
                  Damian @strawberry 3.141
                  @strawberry-3.141 said in stronger Raspberry Pi 3 Alternatives:
                  @Damian You got windows already and magicmirror works also on windows
                  I never thought about that. :-(
                  I just went back over posts here and seen one from @Mykle1 about setting up on his windows PC
                  https://forum.magicmirror.builders/topic/4089/complete-walkthrough-install-magicmirror-on-a-pc-windows-7
                  I just thought that MM would run better on a linux distro system partition, more than on a full Win system? If there is a difference that is?
                  Thanks for that, as this will save some time, and thanks to @Mykle1 for his guide.
                    @Damian I don’t think it really matters. I just prefer Linux … Just easier for me.
                      Damian @cowboysdude
                      Thank you. Really looking forward to seeing the difference in power with MM.
                      fyi… I was going to build an itx like you mentioned in here, but seen a mint condition Lenovo Q180 going for a song on ebay, so bought it, and it is perfect for my next MM. 2.13 GHz 4GB ram 500GB HDD.
                        Makes a HUGE difference :) You’ll love it.
                        • emloweE Offline
                          emlowe Module Developer
                          Here is another option:
                          ASRock N3150DC-ITX Mini-ITX Motherboard - if you can find one.
                          SoC – Intel Celeron N3150 quad core processor @ up to 2.08 GHz with Intel HD Graphics Gen8 @ up to 640 MHz – 6W TDP
                          There are some other Celeron SoC boards that take 19v DC power. The Asus Q1900DC-ITX uses the J1900.
                          Look for “Thin Mini-ITX” normally that means the DC in.
                          -Earle
                            j.e.f.f Project Sponsor Module Developer @cowboysdude
                            @cowboysdude How is the miniATX for heat generation and dissipation when your mirror is hanging up against the wall? Do you need to use a fan on the cpu or gpu? My Pi3 already runs in the high 60’s Celcius without a fan (I’m not using face recognition, or this would likely be much worse)… I’d be concerned that the extra power and limited airflow would generate a significant amount of heat, and adding a fan would result in an annoying whirring sound – ideally I’d want the mirror to operate silently.
                              cowboysdude Module Developer @j.e.f.f
                              @j.e.f.f right now I don’t have it all together so I can’t really answer that question. BUT it has crossed my mind… so I’m going to run a fan off of the motherboard and run it to the top of the ‘frame’ to get rid of the heat. If you buy a high quality fan the noise shouldn’t be a problem…
                                @cowboysdude When you have it all put together, let us know what the noise from the fan is like.
                                cowboysdudeC Mykle1M 2 Replies Last reply Reply Quote 1
                                  @j.e.f.f Will do!
                                    Mykle1 Project Sponsor Module Developer @j.e.f.f
                                    @j.e.f.f said in stronger Raspberry Pi 3 Alternatives:
                                    My experience with the fan.
                                    My thoughts about using a fan:
                                    In my case, if there is any form of ambient sound in the room, I don’t hear the fan at all. If the window is open, if the tv or radio is on, anything at all then I can’t hear the fan. I listened for it when I first installed it.
                                    When do I hear it? At night, when the windows are closed, tv is off, and the house is absolutely silent. The mirror is not in my bedroom, although that wouldn’t matter. My wife’s snoring can mask the sound of a 747 on liftoff.
                                      Well here’s step 1 for my big mirror… I wanted something stronger then a PI so here is my mini-itx in its new home… Cooling is NOT an issue… it’s about 13" square and about 3 inches tall :) Easy to put out of the way … NOW to build a frame for the ‘display’… Coming soon!
                                      HERE is how it all stays cool…this fan is totally SILENT… LOVE IT!
                                      https://www.newegg.com/Product/Product.aspx?Item=N82E16835220067
                                      Mykle1M J 2 Replies Last reply Reply Quote 3
                                        Great idea! Now hurry the hell up with the frame! :^)
                                          @Mykle1 I’m working on it COMING SOON
                                            @cowboysdude is the idea that the mini atx sits beside the mirror as opposed to being built? Say on a console table with just an HDMI cable running to the screen?
                                            • 2 / 3
