    stronger Raspberry Pi 3 Alternatives
    50 Posts 11 Posters 59.8k Views 10 Watching
      Damian @cowboysdude
      @cowboysdude
      Hello can you show the set up of the mini itx in situ at all? And what case you used if any. Thank you
      • SvenSommerS Offline
        SvenSommer @cowboysdude
        @cowboysdude
        I just updated the summary post, could you please check, if there is everything correct?!
        Looking for some building inspiration?
        Check out my large, thin and metal framed mirror on robstechlog.com.
        Modules released:
        MMM-GoogleAnalytics
        MMM-GrafanaChart
        MMM-GrafanaGauges
        • cowboysdudeC Offline
          cowboysdude Module Developer @Damian
          @Damian said in stronger Raspberry Pi 3 Alternatives:
          @cowboysdude
          I will take a pic this weekend but as of right now it’s ‘on the bench’ and I don’t have a case as of yet. More than likely will be designed to attached to the wall of the cabinet and not in a case…
            cowboysdude Module Developer @SvenSommer
            @SvenSommer said in stronger Raspberry Pi 3 Alternatives:
            @cowboysdude
               Operating System Support:
                Windows 10*
                Windows 8.1*
                Windows 7
                64-bit supported only
            Under that I would also put Linux… I’m running Unbuntu on the machine currently which makes it much easier to run MM :)
              I would, and will at some point, use one of these in place of the SSD… to further compact things…
              https://www.newegg.com/Product/Product.aspx?Item=N82E16820228162&ignorebbr=1![0_1500685862979_20-228-162-03.jpg](/assets/uploads/files/1500685862470-20-228-162-03.jpg)
                Damian @cowboysdude
                @cowboysdude said in stronger Raspberry Pi 3 Alternatives:
                Thank you. Yes i looked at cases but none were slim/small enough. Look forward to your snaps to see how yours look set up. What power source did you use?
                  @Damian I am using a laptop power supply :)
                    Damian @cowboysdude
                    thank you. i could not see a link to it in the first post so just wondered what one you chose. looking forward to your pictures of the setup of your itx when you get time
                    • SnilleS Offline
                      Snille Module Developer
                      I just found this one: https://www.kickstarter.com/projects/librecomputer/libre-computer-board-next-gen-4k-sbc-dev-board-for/description
                      It may be an alternative. :)
                      If you cant find it, make it and share it!
                      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                      SvenSommerS 1 Reply Last reply Reply Quote 3
                        SvenSommer @Snille
                        @Snille Yes, very interesting. I liked the idea of comparing the boards with Geekbench. Maybe this is a measurable unit to compare.
                        @cowboysdude Are you willing to run such a Geekbench on your system?
                        Somebody backed this and is going to get a one?
                        Modules released:
                        MMM-GoogleAnalytics
                        MMM-GrafanaChart
                        MMM-GrafanaGauges
                        SnilleS 1 Reply Last reply Reply Quote 0
                        • 1 / 5
