    Input...What do you think?
    54 Posts 9 Posters 45.4k Views 7 Watching
    • cowboysdudeC Offline
      I’m building my own Weather module but would like some input into what others think…
      It has current condition on the top and in the Forecast section it rotates through 10 days of upcoming weather…
      Mykle1M 1 Reply Last reply Reply Quote 3
        @cowboysdude
        I think . . . you are a frickin genius!
        I tip my hat to you, sir. That is some classy stuff!
          @Mykle1 Thank you!
          • SnilleS Offline
            Snille Module Developer
            Looks GREAT, good work! How does it look on the left and right “zones”?
              cowboysdude Module Developer @Snille
              @Snille if on the right it pushes all the way to the border same for the left…no centering has been applied. Here’s some pictures:
              Left side
              Right side
              SnilleS 1 Reply Last reply Reply Quote 0
              • SnilleS Offline
                Snille Module Developer @cowboysdude
                @cowboysdude Ok, looks good! :) I like it.
                  @Snille Yeah I’m on the fence with it… I’ve actually created 3 weather modules… but was having problems with speed… too slow.
                  This one seems to have solved that issue. But I may change the layout… not really sure if I like it. Here’s a capture of another layout from another module I made…
                  This is the one I had problems with…the icons work great on a regular computer but had big issues keeping up on the pi.
                  • SnilleS Offline
                    Ah Nice! like the last one to! Try in in the chromium browser. I’m currently running my mirror in that browser… I also have issues with “Electron”…
                      @Snille I will take a look at that for sure… sometimes I get so busy the obvious just slips right on by me LOL
                        And OPPS just noticed the temp wasn’t showing up… I was working on those lines and forgot I didn’t finish them… LOL Here’s a new capture…
                        • SnilleS Offline
                          Ah, good one. What about current temp?
                            MrEdOne
                            Great work!!!
                            //searching for download button…// :D
                              @Snille GOOD POINT! Going to have a look at that later :)
                              Apparently I changed the api call and I get back TONS more data so I’ll have to reconfigure a bunch of stuff but I don’t mind as the info will be more extensive!!! :)
                                Added current conditions!
                                  @cowboysdude
                                  You’re unstoppable!
                                    And this should do it…
                                    Shows current conditions…rotates through the forecast.
                                    Current conditions has UV index and Barometer… UV shows level and Barometer shows rising/falling/steady
                                    • SnilleS Offline
                                      Looking great! :) How does the forecast work? Do you set a day/days for the forecast? On the preview you are on “Wednesday” and the forecast is for Friday… Where is Thursday? :)
                                      Another question, can you switch between Celsius and Farsighted?..
                                      Mykle1M cowboysdudeC 2 Replies Last reply Reply Quote 1
                                        Mykle1 Project Sponsor Module Developer @Snille
                                        @Snille said in Input...What do you think?:
                                        @cowboysdude said “Shows current conditions…rotates through the forecast.” above ^
                                        Farsighted! That’s funny! :thumbsup:
                                          @Snille Yes as @Mykle1 said…
                                          The top is current condition [at that moment] the bottom rotates through 10 days of upcoming weather [forecast].
                                          I haven’t looked into changing it to C but I will :)
                                            Updated to show C :)
