PIR-Sensor - put your mirror to sleep if not used
126 Posts 37 Posters 213.1k Views 20 Watching
  • K Offline
    KirAsh4 Moderator
    Errr, in your package.json you have a reference to Wunderlist module in the description.
    P 1 Reply Last reply May 6, 2016, 9:17 PM Reply Quote 1
      paviro Admin @KirAsh4
      @KirAsh4 Fixed thanks :)
      – The Doctor
        pugsly
        I don’t have the sensor yet, but installed the module and put the entry into my config.js and when I start mm I get a white screen. Is that normal because I do not have the sensor hooked up yet?
        P 1 Reply Last reply May 8, 2016, 5:38 PM Reply Quote 0
        • E Offline
          EoF
          This is awesome! I will definitely be using this when I get my mirror built.
            paviro Admin @pugsly
            @pugsly I am busy this weekend but I will check next week, for the time being check your web inspector for any errors and make sure there is no mistake in your formatting of the config.js file!
            – The Doctor
              PtrBld Module Developer
              @pugsly: Are you using Node v6? I had the same issue this weekend.
              • I Offline
                incubik
                Hi! Im having the same issue as @pugsly. I do already have the PIR sensor connected but once I launch the MagicMirror the screen goes white.
                This is what I have in the config.js:
                module: "MMM-PIR-Sensor',
                sensorPIN: '2'
                Any thoughts? Thx!
                • I Offline
                  incubik
                  There was a type on my message… sorry. This is what I have done:
                  module: 'MMM-PIR-Sensor’,
                  sensorPIN: ‘2’
                  Note from admin: Please use Markdown on code snippets so it is easier to read!
                  P 1 Reply Last reply May 12, 2016, 6:22 PM Reply Quote 0
                    paviro Admin @incubik
                    @incubik have you checked your Web inspector?
                    – The Doctor
                    • I Offline
                      incubik
                      I have Raspbian install so Im using Epiphany. Does this browser has a web inspector? if so, where? Thx
                      P 1 Reply Last reply May 12, 2016, 6:54 PM Reply Quote 0
                      • 12
                      • 13
                      • 1 / 13
                      1 / 13
