    MMM-MyScoreboard
    277 Posts 60 Posters 624.3k Views 63 Watching
    • P-Bo726P Offline
      P-Bo726
      Love this module! Does this module allow more than one module to run at a time. I can’t seem to get more than one to run. Config file errors out. Could this feature be added? Why would I need this? I’d like to have one league down the right hand side and one down the left hand side.
        Spankythemusical @j.e.f.f
        @j.e.f.f Thank you. Like I said, it’s not a big thing that needs immediate attention. The feed is a public JSON feed from ESPN.
          j.e.f.f Project Sponsor Module Developer @Spankythemusical
          @Spankythemusical all of the current sports my module supports use public JSON feeds. If you want, take a look at, say, NBA to get an idea how it works.
            j.e.f.f Project Sponsor Module Developer @P-Bo726
            @P-Bo726 it does not. Since the module takes care of dividing up the sports for you I didn’t see a reason for multiple instances.
            P-Bo726P 1 Reply Last reply Reply Quote 0
              @j.e.f.f I actually used the MBA section as the template. Unfortunately, I do not have close to enough experience with js to ensure that it is correct. Is there a section of code that controls if the section is hidden or showing? If I could make the section how even without an upcoming game, then I could see if what I’ve done so far is successful.
              • P-Bo726P Offline
                P-Bo726 @j.e.f.f
                @j.e.f.f I’m in the process of building an all sports dashboard and could use multiple instances. I’d benefit from that feature and other may see a use for it as well. Please, Please :)
                  @Spankythemusical you won’t have to touch the front end logic. Your NCAA extension file handles what the front end will receive. Typically the way the other sports work is that the sport is configured with the teams you wish to follow. Then you’ll query for all of “today’s” games, then filter what gets returned to the list of teams to follow. There is a README under the sports directory that goes into more detail about all of this.
                  You’ll also need to add your sport to the list of supported sports in node_helper.js. It’s an array near the top of the file.
                  Lastly, in case there are any special CSS requirements for your sport you may need to add some rules to MMM-MyScoreboard.css. But it should look pretty good right out of the box.
                  In any case I’ll lend a hand when I get back next week.
                    @P-Bo726 I’m travelling all this week but I’ll see what I can do when I get back.
                    • O Offline
                      onetwankyfive
                      +1 to NCAAF
                      This would be amazing
                        @P-Bo726 So it looks like I’d need to make a pretty significant rewrite to make this module work with multiple instances. Right now my node_helper module stores quite a bit of instance information, including what supported sports modules are required – this part in particular poses a real problem being stored as instance configuration, as opposed to a global module configuration.
                        I’ll spend some time thinking about how this might be architected, but I don’t think this will happen any time soon, sorry to say.
                        If you wanted to get your hands dirty, you could manually make multiple instances of this module, but it’s really hacky. Make a copy of the MMM-MyScoreboard directory (Say, MMM-MyScoreBoard2). rename MMM-MyScorboard.js to MMM-MyScoreboard2.js. Do the same to the CSS file and rename it to MMM-MyScoreboard2.css. In the MMM-MyScoreboard2.js file, you’ll need to adjust line 12 Module.register("MMM-MyScoreboard" to read Module.register("MMM-MyScoreboard2" and similarly line 38 return ["MMM-MyScoreboard.css"]; to return ["MMM-MyScoreboard2.css"];
                        Finally, do a search and replace in MMM-MyScoreboard2.css and replace all instances of MMM-MyScoreboard with MMM-MyScoreboard2.
                        Now you have two independent modules - MMM-MyScoreboard and MMM-MyScoreboard2 - that you can configure separately in your config file.
                        You can do this as many times as you like, so long as each time you are using a different name.
                        • P-Bo726P Offline
                          P-Bo726
                          Thank you for the response. I’ll take a look at that hack you provided. If you find some "free’’ time and want to work on the multiple instances I would still find some value in it. No pressure, no hurry. I appreciate all the work you have put into this module and the MM forum in general. Great work!
                            @P-Bo726 Need to get NFL up and running before anything else. Pre-season starts this week!
                            • K Offline
                              Krisalexroberts 0
                              Could you get this working with Pointstreak? Lots of minority leagues/sports use Pointstreak such as the UK Elite Ice Hockey League (EIHL)
                                j.e.f.f Project Sponsor Module Developer @Krisalexroberts 0
                                @Krisalexroberts-0 I’ll take a look to see if there is a public data feed available for this. If so, it should be doable. It will take some time to amass all of the logos and such, but I like the potential for many leagues working with a single API.
                                I still have to finish with NFL – I had it working with last night’s game, but I’d like to run it against next week’s preseason lineup to see if there are any gotchas before I release it.
                                So far I have requests for NCAAF, Pointstreak and eSports. Should be an interesting summer!
                                • K Offline
                                  Krisalexroberts 0 @j.e.f.f
                                  @j.e.f.f you’re a star!
                                  I don’t know if this helps: https://github.com/eikeco/pointstreak-leauge-table
                                    @Krisalexroberts-0 it does. Seems to be hit or miss as to which leagues have data feeds. Are there specific leagues that you’re looking to see incorporated? Doesn’t look like I can just incorporate blanket pointstreak support.
                                    • K Offline
                                      Krisalexroberts 0
                                      I’m selfish so only care about EIHL
                                        @Krisalexroberts-0 An API key is required, but I can’t see anywhere on Pointstreak’s site to get one. Nor can I find any documentation on the endpoints (The link you provided was for standings, not for scores). At this point I’m not sure it’s going to be possible… :(
                                          @Spankythemusical @onetwankyfive I’m in the process of gathering everything I need for NCAAF. I’ve managed to source all of the logos for Division I (FBS 1-A, FCS 1-AA). Forgive me if this isn’t obvious to me –
                                          college football is not really a thing in Canada – but does anyone care about Division II and Division III? From what I can gather, Division I seems to only be what people generally follow.
                                          Sourcing logos for Div II and III looks like it will take some time and work, and I’d like to avoid it if it’s not really something people care about. Even ESPN’s web site only has a few logos for those teams.
                                            @j.e.f.f I believe that division 1 is the one that’s followed by the most people. I don’t even know f it’s possible to get info from the other divisions through the major sites.
                                            Thank you for doing this. I’m curious to see how far off my attempt is from what you come up with.
                                            • 13
                                            • 14
                                            • 1 / 14
