Help to install MagicMirror
I followed the tutorial: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
I have installed magic but I have error messages.
I use a Raspberry pi 2 model B
Who can help me ?
Thanks you very much. -
I forgot this information : npm-debug.log
1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
2 info using npm@3.10.10
3 info using node@v6.11.2
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2
6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2
8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.1.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror
11 silly lifecycle magicmirror@2.1.2~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
12 info lifecycle magicmirror@2.1.2~start: Failed to exec start script
13 verbose stack Error: magicmirror@2.1.2 start:sh run-start.sh
13 verbose stack spawn ENOENT
13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
13 verbose stack at emitTwo (events.js:106:13)
13 verbose stack at ChildProcess.emit (events.js:191:7)
13 verbose stack at maybeClose (internal/child_process.js:891:16)
13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
14 verbose pkgid magicmirror@2.1.2
15 verbose cwd /home/pi/MagicMirror
16 error Linux 4.9.40-v7+
17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
18 error node v6.11.2
19 error npm v3.10.10
20 error file sh
21 error code ELIFECYCLE
22 error errno ENOENT
23 error syscall spawn
24 error magicmirror@2.1.2 start:sh run-start.sh
24 error spawn ENOENT
25 error Failed at the magicmirror@2.1.2 start script ‘sh run-start.sh’.
25 error Make sure you have the latest version of node.js and npm installed.
25 error If you do, this is most likely a problem with the magicmirror package,
25 error not with npm itself.
25 error Tell the author that this fails on your system:
25 error sh run-start.sh
25 error You can get information on how to open an issue for this project with:
25 error npm bugs magicmirror
25 error Or if that isn’t available, you can get their info via:
25 error npm owner ls magicmirror
25 error There is likely additional logging output above.
26 verbose exit [ 1, true ] -
I resolved all my problems.
Thank you. -
@greda For the benefit of others who might run into similar problems, can you post what went wrong and what you did to fix it?
Hi!
I get the same error when using same version of Rasbian.
Any news how to fix it?
