Help to install MagicMirror
Scheduled Pinned Locked Moved Solved Tutorials
6 Posts 3 Posters 8.8k Views 3 Watching
  • G Offline
    greda
    I followed the tutorial: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial
    I have installed magic but I have error messages.
    I use a Raspberry pi 2 model B
    Who can help me ?
    Thanks you very much.
    • G Offline
      greda
      I forgot this information : npm-debug.log
      1 verbose cli [ ‘/usr/bin/nodejs’, ‘/usr/bin/npm’, ‘start’ ]
      2 info using npm@3.10.10
      3 info using node@v6.11.2
      4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
      5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2
      6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2
      8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.2~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/local/games:/usr/games
      10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.1.2~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
      12 info lifecycle magicmirror@2.1.2~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.1.2 start: sh run-start.sh
      13 verbose stack spawn ENOENT
      13 verbose stack at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
      13 verbose stack at emitTwo (events.js:106:13)
      13 verbose stack at ChildProcess.emit (events.js:191:7)
      13 verbose stack at maybeClose (internal/child_process.js:891:16)
      13 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      14 verbose pkgid magicmirror@2.1.2
      15 verbose cwd /home/pi/MagicMirror
      16 error Linux 4.9.40-v7+
      17 error argv “/usr/bin/nodejs” “/usr/bin/npm” “start”
      18 error node v6.11.2
      19 error npm v3.10.10
      20 error file sh
      21 error code ELIFECYCLE
      22 error errno ENOENT
      23 error syscall spawn
      24 error magicmirror@2.1.2 start: sh run-start.sh
      24 error spawn ENOENT
      25 error Failed at the magicmirror@2.1.2 start script ‘sh run-start.sh’.
      25 error Make sure you have the latest version of node.js and npm installed.
      25 error If you do, this is most likely a problem with the magicmirror package,
      25 error not with npm itself.
      25 error Tell the author that this fails on your system:
      25 error sh run-start.sh
      25 error You can get information on how to open an issue for this project with:
      25 error npm bugs magicmirror
      25 error Or if that isn’t available, you can get their info via:
      25 error npm owner ls magicmirror
      25 error There is likely additional logging output above.
      26 verbose exit [ 1, true ]
      • G Offline
        greda
        I resolved all my problems.
        Thank you.
        J 1 Reply Last reply Aug 4, 2017, 4:14 PM Reply Quote 0
          j.e.f.f Project Sponsor Module Developer @greda
          @greda For the benefit of others who might run into similar problems, can you post what went wrong and what you did to fix it?
          • G Offline
            greda
            I had not downloaded the right version of Rasbian. If you want this to work, you need the RASPBIAN version JESSIE WITH DESKTOP
            • 7 Offline
              7even
              Hi!
              I get the same error when using same version of Rasbian.
              Any news how to fix it?
