    Black Screen after Booting Up
    26 Posts 4 Posters 17.2k Views 4 Watching
      j.e.f.f Project Sponsor Module Developer @nickymac12
      @nickymac12 maybe try connecting a LAN cable. it should work with DHCP by default
      • N Offline
        nickymac12 @j.e.f.f
        @j.e.f.f I was able to connect but it still shows a black screen and I still cannot control it.
          @nickymac12 is SSH enabled? if so try to connect that way. That will allow you to check MM’s logs
          • N Offline
            nickymac12
            I am able to connect via SSH now. How do I check the MM’s logs?
              @nickymac12 type pm2 logs mm
                @nickymac12 Also, at this point, you can start disabling modules one by one until MM starts. That should help you figure out the culprit.
                • N Offline
                  nickymac12 @j.e.f.f
                  @j.e.f.f all it responded with was
                  “Spawning PM2 daemon with pm2_home=/home/pi/.pm2”
                    @nickymac12 ok. Try installing the sample config file.
                    Type:
                    cd ~/MagicMirror/config
                    mv config.js config.js.bak (this will back up your existing config)
                    cp config.js.sample config.js
                    pm2 restart mm
                    If magic mirror starts, then you either have a problem with your config or with a module.
                    • N Offline
                      nickymac12
                      So, unfortunately, I only had an 8gb sd card so I used that in my Pi and it is full so it will not write config.js.sample because there is not enough room…
                        @nickymac12 Aha! I’d say that might be your problem. See if you can free up some space, then restore your config file, and restart MM
                        • N Offline
                          nickymac12
                          Oh! How can I clear up space remotely?
                            @nickymac12 you can delete files with the rm command. Be careful with this, because it can’t be undone.
                            Say you wanted to delete some pictures you have in a folder in you home directory. Navigate to that directory like so:
                            cd ~/photo-directory-name (whatever the folder name might be)
                            rm file-name.jpg (this will permanently delete the file)
                            You can remove entire directories with the -r switch. Example:
                            rm -r directory-name
                            And be sure to double-check your typing before you hit enter. deleting things this way is not recoverable.
                            • N Offline
                              nickymac12
                              Is there a way to see what directories or files I have so I know what I can delete?
                                @nickymac12 yes.
                                Use the ls command to see a list of files in the current directory
                                use the cd command to enter a directory e.g.: cd directory-name
                                use the the command cd .. to go back up to the parent directory
                                the pwd command will tell show the path to the current directory
                                cd ~ will take you your home directory
                                • N Offline
                                  nickymac12
                                  how would I restore my config file? Sorry I am new to using terminal and don’t really know all the commands.
                                    @nickymac12 type:
                                    cd ~/MagicMirror/config (Takes you to the MM config directory)
                                    mv config.js.bak config.js (Restores your config file)
                                    pm2 restart mm (restarts MagicMirror)
                                    • F Offline
                                      fox @j.e.f.f
                                      @j.e.f.f said in Black Screen after Booting Up:
                                      Type:
                                      pm2 restart mm
                                      I checked the sample config. No other modules installed only the original. But i still have a blank screen…
                                      What would you propose?
                                      Issues With MMM-WatchDog known?
                                      https://forum.magicmirror.builders/post/29827
                                      Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                                        j.e.f.f Project Sponsor Module Developer @fox
                                        @fox I’d suggest backing up your MagicMirror folder (i.e. rename it) and try a fresh install. By renaming it you won’t lose anything.
                                        • F Offline
                                          fox @j.e.f.f
                                          I Think so
                                          I just punched the
                                          bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                                          in the terminal…
                                          @j.e.f.f do you know how i can solve the two pm2 sessions after a fresh install?
                                          With pm2 status i get always two MagicMirror/mm instances.
                                          If i kill one, it comes back after a few seconds
                                            Mykle1 Project Sponsor Module Developer @fox
                                            @fox said in Black Screen after Booting Up:
                                            type pm2 stop mm or pm2 stop mm.sh in a terminal
