    Black Screen after Booting Up
    26 Posts 4 Posters 15.8k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @nickymac12
      @nickymac12
      So the mirror has no internet connection?
        j.e.f.f Project Sponsor Module Developer @nickymac12
        @nickymac12 maybe try connecting a LAN cable. it should work with DHCP by default
        • N Offline
          nickymac12 @j.e.f.f
          @j.e.f.f I was able to connect but it still shows a black screen and I still cannot control it.
            @nickymac12 is SSH enabled? if so try to connect that way. That will allow you to check MM’s logs
            • N Offline
              nickymac12
              I am able to connect via SSH now. How do I check the MM’s logs?
                @nickymac12 type pm2 logs mm
                  @nickymac12 Also, at this point, you can start disabling modules one by one until MM starts. That should help you figure out the culprit.
                  • N Offline
                    nickymac12 @j.e.f.f
                    @j.e.f.f all it responded with was
                    “Spawning PM2 daemon with pm2_home=/home/pi/.pm2”
                      @nickymac12 ok. Try installing the sample config file.
                      Type:
                      cd ~/MagicMirror/config
                      mv config.js config.js.bak (this will back up your existing config)
                      cp config.js.sample config.js
                      pm2 restart mm
                      If magic mirror starts, then you either have a problem with your config or with a module.
                      foxF 1 Reply Last reply Reply Quote 0
                      • N Offline
                        nickymac12
                        So, unfortunately, I only had an 8gb sd card so I used that in my Pi and it is full so it will not write config.js.sample because there is not enough room…
