    Black Screen after Booting Up
    26 Posts 4 Posters 17.2k Views 4 Watching
    • N Offline
      nickymac12
      I recently made a mirror over the summer and I just moved into my college house. When I plugged my mirror back in it displayed the Raspberry Pi boot up like always and then went straight to the MagicMirror boot up, but after that the screen just goes black. It never brought up my desktop or anything. I have a Raspberry Pi 3 and the application was fully working before. I don’t know how to fix it because my keyboard and mouse aren’t responding when I plug them in.
      If someone could help me out that would be amazing!
      Mykle1M J 2 Replies Last reply Reply Quote 0
        Mykle1 Project Sponsor Module Developer @nickymac12
        @nickymac12 said in Black Screen after Booting Up:
        After the bootup sequence and the screen goes black, have you tried your Alt key? If MM is running, and displaying a blank screen, you might get lucky. The Alt key should drop a menu down from the top. If it does, you won’t see your mouse until you move it all the way up into the menu bar, then you can quit the mirror from the leftmost menu.
        Good luck
          j.e.f.f Project Sponsor Module Developer @nickymac12
          @nickymac12 are you able to connect remotely? over SSH? if so you might be able to check MM’s logs to see if anything went wrong
          • N Offline
            nickymac12 @Mykle1
            @Mykle1 I tried the alt key but nothing happened. The Windows key won’t pull down the menu either.
            • N Offline
              nickymac12 @j.e.f.f
              @j.e.f.f I usually use VNC Connect to connect to it remotely, but since I moved into a new house it isn’t connected to the new wifi so it won’t work.
                @nickymac12
                So the mirror has no internet connection?
                  @nickymac12 maybe try connecting a LAN cable. it should work with DHCP by default
                  • N Offline
                    nickymac12 @j.e.f.f
                    @j.e.f.f I was able to connect but it still shows a black screen and I still cannot control it.
                      @nickymac12 is SSH enabled? if so try to connect that way. That will allow you to check MM’s logs
                      • N Offline
                        nickymac12
                        I am able to connect via SSH now. How do I check the MM’s logs?
                          @nickymac12 type pm2 logs mm
                            @nickymac12 Also, at this point, you can start disabling modules one by one until MM starts. That should help you figure out the culprit.
                            • N Offline
                              nickymac12 @j.e.f.f
                              @j.e.f.f all it responded with was
                              “Spawning PM2 daemon with pm2_home=/home/pi/.pm2”
                                @nickymac12 ok. Try installing the sample config file.
                                Type:
                                cd ~/MagicMirror/config
                                mv config.js config.js.bak (this will back up your existing config)
                                cp config.js.sample config.js
                                pm2 restart mm
                                If magic mirror starts, then you either have a problem with your config or with a module.
                                • N Offline
                                  nickymac12
                                  So, unfortunately, I only had an 8gb sd card so I used that in my Pi and it is full so it will not write config.js.sample because there is not enough room…
                                    @nickymac12 Aha! I’d say that might be your problem. See if you can free up some space, then restore your config file, and restart MM
                                    • N Offline
                                      nickymac12
                                      Oh! How can I clear up space remotely?
                                        @nickymac12 you can delete files with the rm command. Be careful with this, because it can’t be undone.
                                        Say you wanted to delete some pictures you have in a folder in you home directory. Navigate to that directory like so:
                                        cd ~/photo-directory-name (whatever the folder name might be)
                                        rm file-name.jpg (this will permanently delete the file)
                                        You can remove entire directories with the -r switch. Example:
                                        rm -r directory-name
                                        And be sure to double-check your typing before you hit enter. deleting things this way is not recoverable.
                                        • N Offline
                                          nickymac12
                                          Is there a way to see what directories or files I have so I know what I can delete?
                                            @nickymac12 yes.
                                            Use the ls command to see a list of files in the current directory
                                            use the cd command to enter a directory e.g.: cd directory-name
                                            use the the command cd .. to go back up to the parent directory
                                            the pwd command will tell show the path to the current directory
                                            cd ~ will take you your home directory
