    Black Screen after Booting Up
    26 Posts 4 Posters 17.5k Views 4 Watching
    • N
      nickymac12
      Oh! How can I clear up space remotely?
      J 1 Reply Last reply
        j.e.f.f Project Sponsor Module Developer @nickymac12
        @nickymac12 you can delete files with the rm command. Be careful with this, because it can’t be undone.
        Say you wanted to delete some pictures you have in a folder in you home directory. Navigate to that directory like so:
        cd ~/photo-directory-name (whatever the folder name might be)
        rm file-name.jpg (this will permanently delete the file)
        You can remove entire directories with the -r switch. Example:
        rm -r directory-name
        And be sure to double-check your typing before you hit enter. deleting things this way is not recoverable.
        • N
          nickymac12
          Is there a way to see what directories or files I have so I know what I can delete?
            @nickymac12 yes.
            Use the ls command to see a list of files in the current directory
            use the cd command to enter a directory e.g.: cd directory-name
            use the the command cd .. to go back up to the parent directory
            the pwd command will tell show the path to the current directory
            cd ~ will take you your home directory
            • N
              nickymac12
              how would I restore my config file? Sorry I am new to using terminal and don’t really know all the commands.
                @nickymac12 type:
                cd ~/MagicMirror/config (Takes you to the MM config directory)
                mv config.js.bak config.js (Restores your config file)
                pm2 restart mm (restarts MagicMirror)
                • F
                  fox @j.e.f.f
                  @j.e.f.f said in Black Screen after Booting Up:
                  @nickymac12 ok. Try installing the sample config file.
                  Type:
                  mv config.js config.js.bak (this will back up your existing config)
                  cp config.js.sample config.js
                  pm2 restart mm
                  If magic mirror starts, then you either have a problem with your config or with a module.
                  I checked the sample config. No other modules installed only the original. But i still have a blank screen…
                  What would you propose?
                  Issues With MMM-WatchDog known?
                  https://forum.magicmirror.builders/post/29827
                  Useful for PIR-Sensor: https://forum.magicmirror.builders/post/21299
                    j.e.f.f Project Sponsor Module Developer @fox
                    @fox I’d suggest backing up your MagicMirror folder (i.e. rename it) and try a fresh install. By renaming it you won’t lose anything.
                    F 1 Reply Last reply
                    • F
                      fox @j.e.f.f
                      I Think so
                      I just punched the
                      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
                      in the terminal…
                      @j.e.f.f do you know how i can solve the two pm2 sessions after a fresh install?
                      With pm2 status i get always two MagicMirror/mm instances.
                      If i kill one, it comes back after a few seconds
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        Mykle1 Project Sponsor Module Developer @fox
                        @fox said in Black Screen after Booting Up:
                        type pm2 stop mm or pm2 stop mm.sh in a terminal
