    PIR Motion sensor
    16 Posts 6 Posters 13.4k Views 7 Watching
      richardh151
      Jeff thank you very much, I tried to first suggestion and it worked perfectly. As I said I’m somewhat of a novice and on a steep and again enjoyable learning curve. 😊
        richardh151
        Im trying to add a LED strip WS2812B to my python script which switches on and off at the same time as my motion sensor is activated. Whilst there are many scripts out there I struggle to incorporate one into what i have that currently works, can anyone help. My LED GPIO Pin is 17. Any help is appreciated
        This is my current script,
        from gpiozero import MotionSensor
        from subprocess import call
        from time import sleep
        Time to wait until display should turn off after last motion detected
        timeUntilDisplayOff = 600
        The GPIO data pin to which the PIR sensor is connected
        pin = 4
        pir = MotionSensor(pin)
        timer = timeUntilDisplayOff
        while True:
        if pir.motion_detected:
        	print ("Motion detected! Setting timer to " + str(timer) + " seconds.")
        if timer > 0:
        	if timer % 10 == 0:
        		print ("Timer: " + str(timer) + " seconds")
        	timer -= 1
        elif timer == 0:
        	call(['vcgencmd', 'display_power', '0'])
        	print ("Timer is 0. Display turned off. Waiting for motion...")
        	# display is now off. we wait for motion and turn it on
        	pir.wait_for_motion()
        	call(['vcgencmd', 'display_power', '1'])
        sleep(1)
        • KimzerK Offline
          Kimzer
          Interested in the very same thing! But i am trying to make my HUE light strip turn/on off as the screen already does.
          I found this Hue motion
            richardh151 @Kimzer
            @Kimzer thanks but as a novice the suggested scripts blew my mind and seems much more complicated to what I’m currently using. I’m sure there is a way to modify it to switch on the led strip at the same time as the monitor jumps to life from the PIR motion sensor. I have a RPi3 and have it connected but struggle with the script which I’m sure is easy for someone else.
            • KimzerK Offline
              Kimzer
              @Kimzer said in LED Backlight for mirror - PIR to control them:
              Found this hue motion but i couldnt get it to run.
              Anyone that has some input?
              So i managed to do this. Its probably quite a dirty fix. And only setup to work with phillips hue bulbs/strips. But if u want to know shoot me a pm and ill show it. (Y)
              • O Offline
                orayoflighto Project Sponsor @richardh151
                @richardh151
                Have you seen this?
                https://forum.magicmirror.builders/post/26789
                R 3 Replies Last reply Reply Quote 0
                • cowboysdudeC Offline
                  cowboysdude Module Developer @richardh151
                  @richardh151 Here’s a VERY simple one…
                  https://github.com/cowboysdude/Pir-Sensor
                    richardh151 @orayoflighto
                    @orayoflighto what you show is exactly what I need, however struggling with MMM pir Sensor module as my MM shows a conf.js error. So can’t get beyond that. I also have the RGB WS2812B led strips which I discovered r more problematic to control. I feel as though I tried many things but still frustrated with non functioning lights.
                        @orayoflighto I’m struggling with MMM PIR Sensor and constantly get a black screen, this is my coming input, can you advise if I’m doing anything obviously wrong, thanks
                        module: ‘MMM-PIR-Sensor’,
                        sensorGpio: 4, // This is the GPIO port number, not the header pin number
                        relayGpio: false, // This is the GPIO port number, not the header pin number
                        powerSaving: true,
                        relayOnState: 1,
                        relayOffState: 0,
                        turnOffAfterSeconds: 30,
                        debug: false
